Old 02-06-2018, 10:45 AM   #1
CB919ER
CB919ER's Avatar
Default heavy steering
I've driven cars without power steering before and I've never had a problem. I know the steering is quite heavy when the car isn't moving, but it always seemed to get easier once going,
I drove my car home yesterday from Seymour, TN back to Soddy-Daisy, and there were a couple times on some back roads it was all I could do to get the car to turn. Also, it feels as if the steering is sticking and not wanting to return to center. I can turn the wheel in a corner and let go and the steering will stay where I let go.
Is this normal? or is there something else I need to be looking into. I checked my Mechanics handbook for help with possible lubrication of the steering system but didn't have much luck. I probably over looked it somewhere.
Thanks for any help/advice.
CB919ER is offline   Reply With Quote
Old 02-06-2018, 10:55 AM   #2
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: heavy steering
Check your toe in and the kingpin thrust bearings should be taking the load and is the steering bax adjusted properly ? You might consider the teflon rod bushings for the steering arms.
Barry B./ Ma. is offline   Reply With Quote
Old 02-06-2018, 11:01 AM   #3
SeaSlugs
SeaSlugs's Avatar
Sounds like your entire steering system needs looked over and at minimum greased. Castor could be all outa whack as well. Should drive pretty much like a modern car without power steering.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-06-2018, 11:29 AM   #4
Jim Brierley
Check all steering components but sounds like a dry, or worse, gear box.
Jim Brierley is offline   Reply With Quote
Old 02-06-2018, 11:38 AM   #5
3.6rs
3.6rs's Avatar
You are getting older and your arm muscles aren't what they used to be...
3.6rs is offline   Reply With Quote
Old 02-06-2018, 11:50 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Most HARD steering is just WHAT it IS!!! Returning to center by ITSELF, is very RARE!--It's just an Old Design, HIGH EFFORT Steering.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-06-2018, 12:02 PM   #7
CB919ER
CB919ER's Avatar
I'm looking over my lubrication chart and will probably start hitting all the points tomorrow night
I'm only 36, I'm probably one of the youngest guys on here. (I'm aware that you are joking and being sarcastic)
[/QUOTE]
Old 02-06-2018, 12:04 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by CB919ER View Post
I've driven cars without power steering before and I've never had a problem. I know the steering is quite heavy when the car isn't moving, but it always seemed to get easier once going.
I drove my car home yesterday from Seymour...
Is this something that just happened? If so, as other have stated you need to check your steering adjustments and lubrication.
Don't start installing Teflon bushings or shortened pitman arms before rectifying the problems.
Also, it feels as if the steering is sticking....
Sounds like your steering box needs adjustment or oil (not uncommon).
Old 02-06-2018, 12:18 PM   #9
CB919ER
CB919ER's Avatar
That was only the second time I'd ever driving the car. It's be garaged for 20ish years.
Old 02-06-2018, 12:18 PM   #10
3.6rs
3.6rs's Avatar
[/QUOTE]
I don't know if you are the youngest. At age 99 they start counting from 1 again on this forum. Only 2 digits...
So if someone started all over let hear from you !
Old 02-06-2018, 12:22 PM   #11
WHN
In our 29 with a completely restored front end, when car is moving, you can drive with one hand.
I would start with a good grease job, if you can with high pressure lub gun.
Not knowing cars history but reading your notes. I would be leaning towards a group of things that might need attention.
Rebuilt suspension, front end, and brakes, must be correct. They all work together, very important.
WHN is offline   Reply With Quote
Old 02-06-2018, 12:28 PM   #12
V4F
V4F's Avatar
be sure to pack front wheel bearings also
V4f
V4F is offline   Reply With Quote
Old 02-06-2018, 12:34 PM   #13
JDupuis
JDupuis's Avatar
CB919ER, I know exactly what you are talking about.
Check the steering box for oil. My 31 did the same while out on a drive one time. The oil had simply dripped out over time. Good Luck.
Great to have a young guy in our presence. . Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 02-06-2018, 12:43 PM   #14
CB919ER
CB919ER's Avatar
touché good sir!
I'll pick up a grease gun on my way home and lube everything I can. I see in my book that I'm supposed to us "Ford Special steering gear lubricate" in the steering box. Where can I get this stuff or what else can I use. I'm trying to take care of the car and do things right as much as possible.
Old 02-06-2018, 12:51 PM   #15
txkhog
King pins are also a major concern if setting for a while. now you are turning on metal to metal with a very serious load
txkhog is offline   Reply With Quote
Old 02-06-2018, 12:59 PM   #16
CB919ER
CB919ER's Avatar
is there a trick to lubricating these? or am I pulling the spindle off?
Old 02-06-2018, 01:20 PM   #17
Y-Blockhead
Unfortunately that's as good as you get from some...
Old 02-06-2018, 01:22 PM   #18
1931 flamingo
1931 flamingo's Avatar
Get a copy of the Red Book. It will answer many questions. For the steering box, get some PennRite steering box lube (NO leakee). Is there a local club near you?? Someone from it would probably be happy to help you out.
Paul in CT
Old 02-06-2018, 01:29 PM   #19
CB919ER
CB919ER's Avatar
Paul in CT
I've got the redbook, It's a wonderful tool to help.
Old 02-06-2018, 03:05 PM   #20
CB919ER
CB919ER's Avatar
That's going to be my first step, that and hitting all the lube points with a grease gun.
I guess it's rare to have a guy my age with an interest in classic cars like the Model A, and T, without building them into hotrod.
