Old 02-04-2018, 11:37 PM   #1
pbishop
Default Spring less Bendix Opinions?
I have been contemplating changing to a spring less Bendix. Can anyone relate some experience with using one of these?
pbishop is offline   Reply With Quote
Old 02-05-2018, 01:53 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Spring less Bendix Opinions?
I've never had a problem with my original, and wouldn't change.
Old 02-05-2018, 02:26 AM   #3
Dollar Bill
Dollar Bill's Avatar
I find the pozidrive Bendix less prone to kicking out prematurely.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 02-05-2018, 04:28 AM   #4
Karl
Karl's Avatar
I used an inertia drive for a while and went back to an original set up.
My one never engaged right with the ring gear. It would work but inspection after a few months showed it was chewing up the ring gear and itself -Karl
Karl is offline   Reply With Quote
Old 02-05-2018, 03:32 PM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Stay with the original and carry a spare spring.
Jacksonlll is offline   Reply With Quote
Old 02-05-2018, 04:10 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I've used a couple of them and never had a problem .The original starter drive can drop bolts . If the original gets oil and a bit of clutch dust on the helix of the drive , it'll just spin and not engage . I've had no such problems with the modern starter drive .
Old 02-05-2018, 04:57 PM   #7
denis4x4
denis4x4's Avatar
Both my A’s have the modern starter drives. Put them in 10 years ago and never had any issues
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 02-05-2018, 05:30 PM   #8
jrelliott
jrelliott's Avatar
Never had a problem with the modern drive and has been in since 2006.
jrelliott is offline   Reply With Quote
Old 02-05-2018, 06:17 PM   #9
john in illinois
john in illinois's Avatar
I have had good luck with modern drives on my Tudor. Especially since Snyders and probably others stated selling USA Made. V8s take the same starter as model A's and I have a USA Snyder's modern drive in my avatar roadster.
John
john in illinois is offline   Reply With Quote
Old 02-05-2018, 08:39 PM   #10
glenn in camino
glenn in camino's Avatar
I use the modern (tractor style) on all my Model As except my 28 tudor that has an early starter with a smaller shaft.
glenn in camino is offline   Reply With Quote
