Old 01-31-2018, 02:59 PM   #1
oldforder
oldforder's Avatar
Default Torque for oil drain back pipe
I had the oil drain back pipe on the side of the engine off, and I am wondering what is the proper torque for tightening the 2 bolts that hold it on. NormallyI just tighten things good and tight, but seeing the "web" that the bolt goes into, I would think that if I got to strong armed with the bolt, I might pop it out of the block, and that would be really BAD.
oldforder is offline   Reply With Quote
Old 01-31-2018, 05:18 PM   #2
d.
Default Re: Torque for oil drain back pipe
I would just "snug it up". If it leaks, just snug it up some more. Ford never used torque specs. when assembling the Model A originally. Don't overthink this and I think you will be OK, it's just a drain line, it's not running any pressure.
d. is offline   Reply With Quote
Old 01-31-2018, 05:23 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Put a drop or two of permatex on the threads and follow d.'s advice.
Old 01-31-2018, 05:25 PM   #4
Bill Pursel
Bill Pursel's Avatar
11 ft lbs
Bill Pursel is offline   Reply With Quote
Old 01-31-2018, 06:55 PM   #5
oldforder
oldforder's Avatar
Thanks.
Old 02-01-2018, 11:49 AM   #6
larrys40
Good advice from Mike and D. Make sure the Cooper washer is in it. I would NOT put 11jbs of torque on it. You risk cracking the web on the valve cover and I have seen blocks cracked At the web as well.
Snug it up.. all it needs and you can occasionally check if you wish .
Larry shepard
larrys40 is offline   Reply With Quote
