Old 01-23-2018, 05:02 PM   #1
Leatherback 57
Leatherback 57's Avatar
Default Heater to firewall
I have a 29 leatherback with an Autolite heater. What was used between inlet and manifold to seal? Attachment 34799615167444639781651204181.jpg
Leatherback 57 is offline   Reply With Quote
Old 01-23-2018, 05:19 PM   #2
Dale G.
Dale G.'s Avatar
Default Re: Heater to firewall
Nothing. The space between the manifold cover and the inlet in the firewall is supposed to be there to allow fresh air to combine with the heated air.
Dale G. is offline   Reply With Quote
Old 01-23-2018, 07:07 PM   #3
Gold Digger
I rap duct tape around mine
Gold Digger is offline   Reply With Quote
Old 01-23-2018, 08:49 PM   #4
glenn in camino
glenn in camino's Avatar
Good answer, Dale. Any connection that's not steel would probably rattle or burn up, or let bad air into the heat.
glenn in camino is offline   Reply With Quote
Old 01-23-2018, 08:50 PM   #5
CarlG
CarlG's Avatar
The guys in our club that have manifold heaters use a short piece of this:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-23-2018, 11:22 PM   #6
Dick Carne
Dick Carne's Avatar
I have used a short piece of radiator hose on mine. The rubber won't rattle, and there seems to a sufficient amount of outside air to avoid complications from engine odors, etc. Hope this will provide another perspectve.
Dick Carne is offline   Reply With Quote
Old 01-26-2018, 09:34 AM   #7
old31
I use a piece of chevy defroster vent tube tied with a hose clamp.
Old 01-26-2018, 10:26 AM   #8
daren007
Scat tube from your local airport as CarlG shows. It is such a small piece they would throw it away. Most likely cost you nothing.
daren007 is offline   Reply With Quote
Old 11-09-2020, 01:11 PM   #9
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
On the connection from the manifold heater to the body, I used a strip of that silicone grilling sheet that you use on the BBQ. It is flexible and seems to work well. Here is a very short video of it.
https://youtu.be/aUEdiPasUIY
Jacksonlll is offline   Reply With Quote
Old 11-09-2020, 01:30 PM   #10
Ed in Maine
I always have to have the windshield open to the "notch" to prevent getting head aches on long drives! I'm sure there must be a small amount of carbon monoxide under the hood and some seal at the fire wall is a good idea. Ed
Ed in Maine is offline   Reply With Quote
Old 11-09-2020, 08:22 PM   #11
Big hammer
Heat riser tubing for more modern cars available at any auto parts store !
get a bigger hammer tap done
Old 11-09-2020, 09:20 PM   #12
CarlG
CarlG's Avatar
This is what most of the guys here use:
It's called SCAT hose (or tubing), comes in a variety of sizes, easiest place to get it is at your local aircraft supply house, or on line at Aircraft Spruce
Alaskan A's
Old 11-09-2020, 09:59 PM   #13
Bill G
Bill G's Avatar
I have used the soda can method but it rattles a bit. Actually, it just joins in the chorus of other rattles.
I will have to try the BBQ silicone sheet method. Thanks.
Bill G is offline   Reply With Quote
Old 11-09-2020, 10:17 PM   #14
Herb Concord Ca
Years ago when I had mine, I used a length of radiator hose to close the gap.
Herb Concord Ca is offline   Reply With Quote
Old 11-10-2020, 08:28 AM   #15
jwilliams81
jwilliams81's Avatar
As a previous poster said, I leave that gap there. There is more then enough heat to come into the cabin, and it lets fresh air mix with the heated air.
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
