Old 01-18-2018, 04:14 PM   #1
Model A Fan
Model A Fan's Avatar
Default What Kind of 1928-1929 Cowl is This?
I've had this cowl for a very long time. It came off of a 1928/29 AA marked engine. It was used as a log puller for a number of years before I bought it. So basically, it was a gas tank for the engine. Is this an "early" cowl?
Any ideas what kind of Model A it was? Also, what would be a reasonable price if I were to sell it? Thanks!
https://photos.app.goo.gl/If70U3B6z0d7aqdn2
https://photos.app.goo.gl/LnmhmXZlAZFsJVg83
https://photos.app.goo.gl/1MJvwsaP4lOQQOUj2
https://photos.app.goo.gl/GeC3IlshcmLlvo8x2
https://photos.app.goo.gl/NU59ZNooNQnLPTPG2
https://photos.app.goo.gl/a45JMxX2nxzIGBXA3
https://photos.app.goo.gl/Ph4XKo38x1UiNsUR2
https://photos.app.goo.gl/lK8qEh83eYCgk4BC3
https://photos.app.goo.gl/APEn6w21FQXIoKXa2
https://photos.app.goo.gl/Zvuevh7uo7R8brl92
https://photos.app.goo.gl/KnTvbKMt21UA77yi1
https://photos.app.goo.gl/eMmlYhlHx6nfoYsD3
https://photos.app.goo.gl/6J3er7SdRsZJqjCm2
Model A Fan is offline   Reply With Quote
Old 01-18-2018, 04:43 PM   #2
wrndln
Default Re: What Kind of 1928-1929 Cowl is This?
It appears to be from a 28/29 coupe, tudor, CCPU or AA truck. I am not sure about a fordor or cabriolet. It is definitely not a roadster, phaeton or OCPU. As far as a price, it look kind of rough and the gas tank is probably about the only part that is restorable without a ton of effort and maybe the firewall. It might bring a couple hundred bucks mainly for the gas tank assuming the gas tank is in decent condition - the gas tank filler has something on it, are the threads OK? Just my opinion.
Rusty Nelson
Old 01-18-2018, 04:49 PM   #3
Aerocraft
Aerocraft's Avatar
It's for a Ford built body. Not Briggs (Fordor or Cabriolet) or Murray (Fordor).
Aerocraft is offline   Reply With Quote
Old 01-18-2018, 04:51 PM   #4
Chuck Dempsey
Chuck Dempsey's Avatar
Is that the usual 28-29 'threaded' gas cap? Or the 30-31 'slot' variety?
Chuck Dempsey is offline   Reply With Quote
Old 01-18-2018, 05:12 PM   #5
Pickupman
The cowl is off a 1928 - Mid1930 Pickup/Truck. Just look at the hinges. Those hinges are correct for Pickups/Trucks. It appears from the cap on it, that it might be the slotted style. If thats the case then this cowl was used from January 1930 to Mid1930.
Pickupman is offline   Reply With Quote
Old 01-18-2018, 05:15 PM   #6
JDupuis
JDupuis's Avatar
That looks to be a very early 30 ccpu or AA. The slot fuel tank was used on the early 1930 truck. We have a AA on the farm (dump truck) with same cowl and a Brantford Cab on it. Hope this helps. Is there a date stamp on the firewall?
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 01-18-2018, 05:21 PM   #7
flatford39
Yeah...that is an early 30 AA truck cowl from the bayonet style gas cap on it. The tank in good condition is worth a few 100 dollars. No to so much if it needs to have rust holes repaired.
flatford39 is offline   Reply With Quote
Old 01-18-2018, 06:52 PM   #8
Model A Fan
Last I know it was used, so I'm assuming it is usable. Is $90 too little to ask on it? I haven't committed to selling it but I should have asked what it was worth first.
Old 01-19-2018, 06:33 AM   #9
JDupuis
JDupuis's Avatar
I feel that that price would be appropriate. Jeff
Old 01-19-2018, 08:30 PM   #10
jm29henry
jm29henry's Avatar
Ford built body is correct
jm29henry is offline   Reply With Quote
Old 01-19-2018, 08:41 PM   #11
DougVieyra
DougVieyra's Avatar
it looks to have an after-market accessory (hinged) locking cap.
DougVieyra is offline   Reply With Quote
Old 01-19-2018, 10:40 PM   #12
Model A Fan
$90 or a few hundred bucks? I saw tanks on eBay for $150-$300, seems like a wide variety and range of prices.
The cap is not hinged, just a normal twist on/off style.
Old 01-20-2018, 12:39 PM   #13
V4F
V4F's Avatar
looks like a '30 with radiator cap or old gas cap
V4f
V4F is offline   Reply With Quote
Old 01-20-2018, 01:50 PM   #14
Purdy Swoft
Purdy Swoft's Avatar
Value or beauty is in the eye of the beholder . If a restorer looked at it they would clearly see the damages to the front firewall part of the tank . This part of the tank doesn't bolt on and would be a pain to replace or repair, same for the lower firewall . I can't tell much about the rear part of the tank from the pictures . My thought is it may be considered priceless to a person that wanted rare yard art . If I needed a tank I would look for a better candidate . No harm meant, Just my thoughts . If someone offers several hundred dollars, you would be very lucky .
Last edited by Purdy Swoft; 01-20-2018 at 06:39 PM. Reason: added spaces.corrected spelling .
Old 01-20-2018, 09:10 PM   #15
SteveB31
SteveB31's Avatar
1928-1929 pickup/aa truck only
SteveB31 is offline   Reply With Quote
Old 01-20-2018, 09:12 PM   #16
SteveB31
SteveB31's Avatar
Actually, early 1930 AA truck. Slide in hinges= pickup or AA. Twist on gas cap makes it early 1930 Aa truck.
