Old 01-18-2018, 11:12 AM   #1
Ron P.
Default Generator Output
Recently rebuilt my generator for my 31 coupe. It appears i'm not getting any output from the generator. I moved the third brush up and down with no change in output. The amp meter looks good, when i turn the lights on it discharges. But with the engine running i get no charging on the amp meter.
What could be my problem, wiring or a short?
Ron
Ron P. is offline   Reply With Quote
Old 01-18-2018, 11:36 AM   #2
Charlie Stephens
Default Re: Generator Output
Have you done anything else recently, like change the wiring?
Charlie Stephens
Old 01-18-2018, 11:42 AM   #3
4port
4port's Avatar
Try polarizing the generator. Momentarily connect a jumper wire between the the two posts on the either side of the cutout. An 8" wire with bare ends can be held by hand against one post and touched on the other.
Remember when flying low inverted, down is up, and up can be expensive.
4port is offline   Reply With Quote
Old 01-18-2018, 11:47 AM   #4
redmodelt
redmodelt's Avatar
Was it working before? Did you have the armature checked?
Old 01-18-2018, 11:47 AM   #5
4port
4port's Avatar
Another simple bench test is to see if the generator will " motor", run like an electric motor connecting a set of battery cables from a battery to ground on the generator case and the output terminal post. If it won't motor it won't put out charge current.
Old 01-18-2018, 12:32 PM   #6
Ron P.
Did all the above but still no output. New Armature and coils. Does one wire from the coils go to ground?
Old 01-18-2018, 01:00 PM   #7
Purdy Swoft
Purdy Swoft's Avatar
One of the field coil wires usually grounds under the output terminal or in some cases under a ground screw . the other field coil wire connects to the third brush . If the field coil wires get reversed the generator will still charge , usually at maximum rate . Moving the third brush up or down will have no effect on charge rate if the field coil wires are reversed ... If the wires are reversed it will damage the field coils very quickly . Sometimes when polishing up the commutator The brass will will transfer and ground out the commutator. I always use a hacksaw blade to under cut the gaps on the commutator . If you tested to see if the generator would motor and accidently touched the ground wire to the out put post , you will need to repolarize the generator or it won't charge .
Old 01-18-2018, 07:56 PM   #8
Patrick L.
Patrick L.'s Avatar
You really didn't answer that question, did it motor ?
Regardless, Purdy gave the info.
Old 01-18-2018, 11:33 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I don't see cutout mentioned. Are you testing it in the car? Have you tried to bypass the cutout?
Old 01-19-2018, 07:50 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Polarize it, then try it.
If no charge at fast idle, then jump across the cutout with a wire while the engine is at fast idle.
Still no charge, then polarize it with the fan belt removed, and if it spins opposite of the normal rotation, the field coils need to be swapped side for side.
