Old 12-20-2010, 04:25 PM   #1
flathead47
flathead47's Avatar
Default Mitchell overdrive
I am thinking about installing a mitchell overdrive unit in a 46 - 48 ford convertible. Does anyone have experience with this, installation tips, pictures of installation , was it worth the effort. Thanks.
flathead47 is offline   Reply With Quote
Old 12-20-2010, 05:39 PM   #2
oldford2
oldford2's Avatar
Default Re: Mitchell overdrive
I am considering one for our 46 so will be interested in the response to this post. I understand they are a quality gear changer and relatively easy to install. John
oldford2 is offline   Reply With Quote
Old 12-20-2010, 05:49 PM   #3
uncle max
uncle max's Avatar
Five hours to install - no looking back. Literally.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 12-20-2010, 05:52 PM   #4
John T
Have one in my 38 Ford and it is great.
John T is offline   Reply With Quote
Old 12-20-2010, 07:45 PM   #5
52merc
52merc's Avatar
i believe theres a couple of ratios that you can get with this set up hopfully someone who has one in a car like yours will advise trev
52merc is offline   Reply With Quote
Old 12-20-2010, 08:57 PM   #6
jerry grayson
Most 46's have a 3.54 rear gear and an overdrive is going to result in serious underpower.
jerry grayson is offline   Reply With Quote
Old 12-20-2010, 09:19 PM   #7
Bruce Compton, Canada
Smile Re: Mitchell overdrive
I have one in my "36 and it's great. My '36 has a 3.78 rear and I have the "36"% Mitchell. Overall I believe they are a well built rugged overdrive that provides a viable option over the pricey and somewhat fragile Columbia if you're not into counting judging points at a car show. Before you order one, do the math on their advertised ratios as they think that overdrive "ratio" and "reduction" are the same. In Reality their "36 % " reduction is actually around 29% ( same as the Borg-Warner and Columbia ratios) while their "26%" is really closer to 20%. If your rear end ratio is 3.78 or higher, I'd suggest getting their 36%. It makes a huge difference in driveability that you will really enjoy. Bruce
Bruce Compton, Canada is offline   Reply With Quote
Old 12-20-2010, 10:02 PM   #8
52merc
52merc's Avatar
i think you will find its 3.78 standard ratio for 46fords
Old 12-20-2010, 10:26 PM   #9
flathead47
flathead47's Avatar
My 47 has a 4.11 rear gear and is basically a 50-55 mph car. I have considered the 3.54 rear gear as an option , but the mitchell overdrive seems like a interesting solution to easily obtain a 65 mph car. I do not want to modify the floor of the car or have any clearance problems with the installation so that is why I was hoping there would be some pictures out there from someone who has installed one in a 46-48 ford.
Old 12-21-2010, 06:07 AM   #10
flatmotor40
flatmotor40's Avatar
I put one in my 40 conv and it was a 36% and it does great and if you see a long hill just speed up a little and it will do just fine.Sue was really helpful because I bought it and it was a year or so before I finished the car and they siad they would make it good anyway so great people to work with
flatmotor40 is offline   Reply With Quote
Old 12-21-2010, 06:09 AM   #11
flatmotor40
I forgot ot tell you I oped for the cable because I didn't want a hole in the new floor
Old 12-21-2010, 12:40 PM   #12
Django
Django's Avatar
I saw their ad in the V8 Times and was intrigued myself. How much are they?
Obsessed with all things 1936 Ford since birth... thanks Dad.
Django is offline   Reply With Quote
Old 12-21-2010, 01:21 PM   #13
John T
In my 36 Coupe I have a 354 rear and a 36% Mitchell and it works fine, but I do have a approx 370 cu. in. flathead for power.
Old 12-21-2010, 06:35 PM   #14
38 coupe
38 coupe's Avatar
Does anyone have pictures of the Mitchell installed under their vehicle and of the control, either cable or shifter?
Old 12-21-2010, 06:45 PM   #15
41PICUP
41PICUP's Avatar
I have one in my 41 pickup, running 3:54s, love it.
Easy install, take oout the old torque tube and driveshaft, then bolt in the Mitchell.
Any questions, call and talk to Sue Mitchell, she has all the answers, good people to deal with. Cost is about $2100. Either 26% or 36% overdrive.
41PICUP is offline   Reply With Quote
Old 12-21-2010, 07:03 PM   #16
38 coupe
38 coupe's Avatar
Thanks for the picture. That looks like it would hit the floor under my 37 (and 38 and 39 and my Dad's 40). Does anyone have pictures of one installed under a passenger car?
Old 12-21-2010, 10:01 PM   #17
CarPapa
Wanted to use one in my '34 sedan, but would have had to cut the seat riser and floor. Decided against it.
CarPapa is offline   Reply With Quote
Old 12-21-2010, 10:08 PM   #18
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Hey John T, tell me a little bit more about your 370ci flathead. That really snapped me awake. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 12-21-2010, 10:18 PM   #19
52merc
52merc's Avatar
me to !!
Old 12-22-2010, 06:14 AM   #20
flatmotor40
What I had to do was move the shift arm to the bottom instead of top so it would not hit the floor when you hit a bump or someone was in the bask seat.But I had put Posie reverse eye springs on mine and it lowered it a little but teh only difference is the engage you push in instead of pull out the cable.Sue was a great help and I used syn 90w oil in mine
