Old 12-20-2010, 04:17 PM   #1
lucky
lucky's Avatar
Default Firewall removal
After removing all the fastners should the firewall seperate from the body and cowl? [this is in a 1934 pickup.]
thanks, marvin
lucky is offline   Reply With Quote
Old 12-20-2010, 04:20 PM   #2
ora masters
Default Re: Firewall removal
lucky i know the 32 does since the cabs are allmost the same i would say yes
ora masters is offline   Reply With Quote
Old 12-20-2010, 05:10 PM   #3
Bruce Lancaster
Isn't that entirely spot welded? I think any fasteners you are seeing are for hood hinge bracket, cloth padding, etc.
You are all done except for drilling out about 50 spotwelds...
'32 is about the complete list of Ford V8's with removable firewall. My '33 firewall needs to come out for some retrofitting, since it is now employed as part of a '32, and I am not looking forward to the festivities!
Bruce Lancaster is offline   Reply With Quote
Old 12-20-2010, 06:38 PM   #4
Charlie Stephens
You hit on the best way to tell the '32 from the later cabs.
Charlie Stephens
Old 12-20-2010, 10:04 PM   #5
52merc
52merc's Avatar
theres a special drill tip for taking out spot welds makes the job a lot easier
52merc is offline   Reply With Quote
Old 12-21-2010, 10:09 AM   #6
itslow
itslow's Avatar
The previous posts are correct; you will need to drill out a couple dozen spot weldsand a spot weld cutter makes the job much easier. Not really too tough or time consuming with the cutter; it'd be well worth the $16 to buy one.
This goes for both '33 and '34. The '32 uses a completely different cowl band for the firewall mounting.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 12-21-2010, 10:41 AM   #7
lucky
lucky's Avatar
Thanks very much.
marvin
