Old 12-08-2017, 11:28 AM   #1
rosenkranswa
rosenkranswa's Avatar
Default Light switch won't lock
Old problem, thought I'd see if there are any ideas from the forum:
1929 Roadster, original light switch and bail. Switch won't lock when twisted closed. Bail holds it in place for normal driving, but lights are a little wonky due to the contacts not being tight.
Back probably 15-20 years ago I had opened the switch to replace the horn rod and it just never went back together right. About once a year I'll try to get it back together and it almost works, but not quite. I don't drive it much at night, so its more annoying than anything else, but I really need to get it right.
Tried various grippers, filter wrenches, etc. to no avail. Any ideas?
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 12-08-2017, 05:06 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Light switch won't lock
Make sure everything is seated properly before trying to reassemble the parts. Make sure the slots are free of debris. You can remove the horn rod a bit and see if that is a source of your problem.
Old 12-09-2017, 07:56 AM   #3
Mike
Mike's Avatar
Wayne,
Bend the bail so it fits a little tighter, or try another ORIGINAL light switch housing.
Mike
Mike is offline   Reply With Quote
Old 12-09-2017, 12:47 PM   #4
J Franklin
J Franklin's Avatar
You say the assembly is original, do you mean to the car or factory. Maybe a mix of parts? You might need to punch the pins out a bit or squeeze the other side to get a tighter connection.
Old 12-09-2017, 01:21 PM   #5
rosenkranswa
The switch and bail are factory original. I've cleaned the slots and pegs several times to no avail. Hadn't thought about the switch rod being a scootch too long, might try that next.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 12-09-2017, 01:58 PM   #6
ericr
ericr's Avatar
if I were you I would go through the hassle of removing the wire harness assembly and work on the switch outside of the car. they are a touchy fit at best and it is awkward to analyze your problem with the unit still in the car.
ericr is offline   Reply With Quote
