Old 12-07-2017, 08:18 PM   #1
gearheadbill
gearheadbill's Avatar
Default Need 1940 Coupe seat removal advice
For several reasons I need to remove the seat from my 40 coupe. Are the side 'covers' (don't know what the real name is...see photo) removable with the seat in the car? If not, how in the H#$"* does one get at the bolts to R&R the thing? Seems like I need a hand with 9 fingers and arm about 2 inches in diameter to get at the back bolts.
gearheadbill is offline   Reply With Quote
Old 12-07-2017, 08:33 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Need 1940 Coupe seat removal advice
I use a small ratcheting box wrench. To install that bolt, I shove my arm in from the front. Yep, tight fit and yep, I get scraped up but it's the only way I know.
Old 12-07-2017, 08:48 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
It all comes out as a unit after you unbolt it from the floor. Then you have to contend to the bellows that is attached to the backrest to the package tray.
Ken/Alabama is offline   Reply With Quote
Old 12-07-2017, 10:17 PM   #4
gearheadbill
Kube: Do those seat bolts thread into a captured nut, or are they through bolted?
Ken: auxillary seats...no package tray etc..
Old 12-07-2017, 10:18 PM   #5
gearheadbill
Old 12-07-2017, 11:12 PM   #6
swoopNZ
MEMBER EMERITUS
For a 5 window coupe ( lift-up style seat ) they are sleeve type ( captive ) nuts.
3 x 5/16" UNC threads each side from memory.
Best to take the entire seat out and turn it upside to remove them.
Cheers,
Chris.NZ.
swoopNZ is offline   Reply With Quote
Old 12-08-2017, 06:20 AM   #7
mike42
mike42's Avatar
When I re-did those panels I took the seat out. It's really not that big of a deal to take out seat and a lot easier too. I also had to un-stick the seat adjuster at the time.
mike42 is offline   Reply With Quote
Old 12-08-2017, 08:33 AM   #8
fortyfords
fortyfords's Avatar
A very strong back or two weaker backs.
fortyfords is offline   Reply With Quote
Old 12-09-2017, 02:02 AM   #9
47Merc
I have had the front seat in my 40 Coupe which has jump seats out a few times and getting the bolts out is difficult. Much easier if it is on the hoist with the wheels about 3 feet off the ground and you slide the seat back and forward to get at the bolts.
I also found to physically remove the seat from the car if you are on your own it is easier if you remove the 2 back sections first as it cuts the weight in half. When you have it unbolted, push a small plank across the car underneath the seat supports and then slide the whole lot out the door on the plank.
47Merc is offline   Reply With Quote
Old 12-09-2017, 07:22 PM   #10
fortyfords
fortyfords's Avatar
That still sounds like back breaking work!
Old 12-09-2017, 08:04 PM   #11
Kube
Super Moderator
Kube's Avatar
Caged nuts as you thought.
Old 10-17-2023, 02:16 AM   #12
FordFanMan
FordFanMan's Avatar
Thanks for sharing! I plan to remove the seat in my 40 coupe.
Live, laugh, and love family.
FordFanMan is offline   Reply With Quote
Old 10-17-2023, 06:39 AM   #13
marko39
if you think they are hard to remove wait to you have to put them back. on my 39 i ran bolts up from bottom for the rear ones and it was easier to get two nuts on than line up bolts.
marko39 is offline   Reply With Quote
Old 10-17-2023, 09:01 PM   #14
Lawson Cox
Lawson Cox's Avatar
This posts got me to thinking about removing the rear seat from my old 48 Chevy coupe for a little "afternoon delight" in my younger days. Precious memories. LOL
Old 10-18-2023, 11:17 AM   #15
V8 Bob
V8 Bob's Avatar
It's much easier to take the seat apart before trying to remove the entire assembly, at least with a split back. Remove the seat backs first, one by one, then lift out the bottom. What's left is the bare frame and mounts with easy access to the bolts by running the adjusters back and forth. Same holds true for installation, just reverse the order.
V8 Bob is offline   Reply With Quote
