Old 12-19-2010, 08:35 AM   #1
alaskan_tnt
Red face Need How-to info
How do you calibrate a 1962 Speedometer? What equipment or tools are needed? No one around here works on anything that doesn't have a computer attached. Changing the cable and gear didn't fix the 10-15mph discrepancy. Thanks for the help in advance.
alaskan_tnt is offline   Reply With Quote
Old 12-19-2010, 10:14 AM   #2
George/Maine
George/Maine's Avatar
Default Re: Need How-to info
The rear end gears affect,trans gears, and tires.
If the needle is off at zero you maybe able to bend it.
Oil it and oil cable.may try another speedometer.
George/Maine is offline   Reply With Quote
Old 12-19-2010, 03:57 PM   #3
ford1
i think there is another gear on the rear shaft that drives the speedo gear, check with your local trans shop
ford1 is offline   Reply With Quote
Old 12-20-2010, 09:39 AM   #4
Dave72dt
You'llneed to change the gear drive set up inthe transmision. One piece on in the end of the speedo cable. The other is on the tailshaft of the transmission. Pullint the tailhousing off the trans will usually get you there.
Dave72dt is offline   Reply With Quote
Old 12-20-2010, 11:22 AM   #5
JeffB2
JeffB2's Avatar
In most cities look in the Yellow pages under "Speedometer Repair" you should be able to locate a shop that way.If you can't find one contact Dick's Speed-O-Tach in Phoenix been in business since 1941 at 1(602)279-6463 website is www.dicksspeedotach.uswestdex.com
JeffB2 is offline   Reply With Quote
Old 12-22-2010, 10:00 AM   #6
LOWRIDER
LOWRIDER's Avatar
Another place you can contact is Bobs Speedometer. They have a web site bobsspeedometer.com & 800-592-9673 phone #. They have been in business since 29' and are local legends.
LOWRIDER is offline   Reply With Quote
Old 12-22-2010, 08:03 PM   #7
40 Deluxe
Has the rear end been changed? If it has an auto trans, a standard trans rear end may have been put in or vice-versa. Or, trans may have been changed from standard to automatic, or vice-versa. Cars with an overdrive trans used yet another rear end ratio, too. The factory had the correct speedo gear for each combination, trick now is finding them.
Old 12-23-2010, 11:49 PM   #8
coilover
Bow Tie Overdrives has a chart where you plug in your tire size and rear end ratio and it gives the drive gear and driven gear tooth count for correct speedo reading. It's for GM so the gear part numbers and colors (on GM plastic gears) won't mean anything but the tooth count will be right for any brand car. Ford probably has gears with the same tooth count. A good speedometer shop will also have an adaptor that fits on the tranny just like the speedo cable and then the cable fits on the other end of this. They can either over or under drive the output of the speedometer gears in the trans.
coilover is offline   Reply With Quote
Old 12-24-2010, 09:17 AM   #9
Frank The Plumber
speedometer service 414 463 6660
Frank The Plumber is offline   Reply With Quote
Old 12-24-2010, 09:40 AM   #10
George/Maine
Some thing to think about.
Before someone takes your money see if the miles are correct.Drive 3 miles and check odomometer.
Old 01-15-2011, 07:49 AM   #11
JerseyJim
JerseyJim's Avatar
I'm a little late seeing this post. But thought that I would put my two sense in any how. You didn't indicate whether it is high or low? You also didn't indicate if the difference in speed is consistent or varies according to speed. If it is a speedo gear issue, the percentage of variation should be consistent at all speeds. That means that as your speed increases, the variation should increase. Assuming this to be the case, the next question is did the replacement speedo gear that you put in have the same number of teeth? A fairly wide variety of gears are available. Depending on whether you are faster or slower, you can typically buy gears with more or less teeth as required.
On older cars, it isn't tough to figure out which one to use. These older transmissions (with the exception of over drive transmissions) typically have a final gear ratio of one to one. Drive your car at a set speed. Let's say 60 miles per hour. Get someone to pace you with a vehicle with a known accurate speedometer. At 60 in your car, ask them what they are reading in theirs.
If they are reading 70 miles per hour, simply divide your speed into theirs. 60 into 70 will give you 1.16. Now let's assume that you have 16 teeth on your existing gear. You need to reduce the number of teeth to increase your speed reading. So divide the number of teeth on the existing gear... let's say for example that it is 15 by 1.16 and you will get 12.93. Use a 13 tooth gear and your speedometer should be almost dead on.
If they are reading 50 to your 60, here's the way it works: Divide your 60 into their 50 and you get .833. Divide 15 by .833 and you get 16.8. You would round up to 17. Again you will be very close.
Hope this helps.
JerseyJim is offline   Reply With Quote
Old 01-15-2011, 07:56 AM   #12
JerseyJim
JerseyJim's Avatar
An additional comment... Older speedometers using gear were notoriously inaccurate because of the fact that that are only so many speedo gear teeth variations. Car reviews used to always list the speedometer variation as a technical spec. Plus or minus 5 MPH was pretty much the norm.
