#1 |
I bought this air cleaner so I could use it on my 56 Fairlane after changing the manifold and carb. The air cleaner is supposedly from a late 50's or very earl 60's Ford product. It fits the Autolite 4100 carb perfectly. The problem is I can't find a filter for it. The filter I think I need should probably be:
Top - 10.39" O.D., 7.28" I.D Bottom - 9.78" O.D, 7.28" I.D possibly 3.22" tall. I'm stumped. It's a Ford product. It shouldn't be that hard to find. No catalog shows a filter that will fit. The closest one I found is from a Desoto. It fits but not perfectly. I think the filter I need might be an AC A82C filter but I haven't found the dimensions for it.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic |
#2 |
Not sure this helps, and I wouldn’t pay this for NOS stuff that decomposes.
https://www.ebay.com/itm/VINTAGE-NOS...-/351677823294 Maybe an Edsel site has a replacement/solution that works. |
#3 |
Yours looks very similar to mine...if you check my blog thread you can see quite a few photos. Want me to check my filter number?
Red Lion, Pennsylvania Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
#4 |
If the E-Bay info is correct, (and I do not find the PN on GOOGLE), A82C may be discontinued.
AC does have a current PN, A2882C for the period application. It gives no sizes. Maybe contact AC? https://www.acdelco.com/contact-us.html
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
#5 |
Get a WIX paper catalog,, listings by size
#6 | |||
I think that's how I found my Desoto filter. Quote:
That's one of the listings where I found the part number. Thanks everyone.
#7 |
Post up some pictures of that air filter from all angles along with the dimensions.
I have a 58 retractable currently in the shop and I believe its the same air cleaner. Its a 332 engine. It uses a Purolater A40013 element. The Purolator specs are below and are close to what you are asking for. https://aftermarketfiltrationexperts...ternative-qty2 Perhaps its the same ????? Oldmics Last edited by Oldmics; 12-07-2017 at 09:59 PM. |
#8 |
I'll have to measure the filter housing when I get a chance.
#9 |
Try Concours Ford Parts .
#10 |
Some shots of the air filter that I believe is the same as yours.
If you notice the lid is flush with the Purolotor element. I believe your asking for that 3" height is a bit much as your lid sits a bit high. I think the A40013 filter I am suggesting is correct.
#11 |
More Pics
#12 |
Oldmics is probably on the right track. If not, I sent a pm. I’ve done this on similar filters. Not concours correct.
#13 | |
http://www.airfilter-crossreference....ROLATOR/A40013 I tried earlier with the WIX dimensions catalog and found nothing with the height needed being listed. Maybe re-measure height?
#14 | ||
Yeah, I think you are correct also. I could find no referece to an element that tall. Continued From Previous Thread- https://www.fordbarn.com/forum/showt...64#post1562664
#15 |
I think I measured from the top of the recess of the air cleaner body down to the bottom inside and got nearly 3.25 inches.
I had actually bought the listed filter from NAPA back when I got the air cleaner and it was nearly an inch short. It was just hanging from the top rim with a sizable gap underneath.
#16 |
Here's a few phots of the air cleaner and the inside measurement that shows that the filter needs to be over 3" tall.It's without a doubt a Ford produced air cleaner as it even has indentations to clear the usual bell crank and coil.
#17 | |
Something doesn't ring with the rear shot. EDIT- ... ...Can you measure the assembly as it lays on a flat surface as to OD and HGT? You said previously you had a FORD C3VY 9601-A element equivalent and it did not fully reach the bottom support? You also said the seller repainted the cleaner? Do you see any signs of a previous color, black, blue, white or gold?
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) Last edited by KULTULZ; 12-10-2017 at 07:07 AM. |
#18 |
OK, I think I have found it. It was not in the 60/64 MPC (must have gone obsolete and was deleted from FINAL ISSUE).
Went back again to the 1967 READY REFERENCE CATALOG and it was listed there (I think). It only gave two dimensions, 9.74" OD and 3.13" H. It is listed only for 64 FORD and MERC. Service PN C4AZ 9601-A. No reference found on GOOGLE. This must have been a very limited production run. Maybe explains why the guy got rid of it. I think I read oldmic saying he had a period OSI Catalog. Maybe he can chase it and get an earlier PN. I will keep looking.
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) Last edited by KULTULZ; 12-10-2017 at 10:55 AM. |
#19 |
Green Ford Sales
http://www.greensalescompany.com/ shows that they have 6 of the C4AZ 9601-A in stock. Have to call them for pricing The OSI information that I have is from 1955 to 1961. The 1964 MCR book crosses the service number (C4AZ 9601-A) to the actual part of C4AF9601B Oldmics Last edited by Oldmics; 12-10-2017 at 01:36 PM. |
#20 | |
So it is a CROSS REFERENCE CATALOG you have? An OSI (Obsolete-Supersede-Interchange) Catalog will give SERVICE PN upgrades once they are out of the PRICE BOOK. Nice to have either or both. THANX Oldmics ...
