12-01-2017, 10:48 AM | #1 |
gear shift knob adapter
Where can I get adapters for original marble gear shift knobs to be able to use on a model a gear shift?
12-01-2017, 10:52 AM | #2 |
Re: gear shift knob adapter
I found the right thread size nut and epoxied it in the knob. Worked great.
12-01-2017, 11:00 AM | #3 |
I am trying to find a couple of the original type adapters which I believe were made out of brass. I have seen them at Hershey before. Thanks for your reply.
12-01-2017, 11:10 AM | #4 |
Oil the shifter threads, fill the knob with JB-Weld & screw it on.
Bill Simple
12-01-2017, 11:12 AM | #5 |
I just drill and tap a brass bolt and cut it off and make what ever you need. the Model A is 5/16" fine thread.
12-01-2017, 11:54 AM | #6 |
12-01-2017, 12:10 PM | #7 |
