Old 11-26-2017, 08:04 AM   #1
Eric Lewis
Eric Lewis's Avatar
Default Removing Break Drums
After getting the Ole Girl running this week for the first time I put her up on jack stands to begin inspecting, adjusting the brakes. Pulled three brake drums with no problem, got to the left rear and could not get it to budge, used a hub puller, a BFH and heat and low and behold, I had forgotten to release the emergency brake.............duh. Once I stumbled on to that it popped right off.
Lesson Learned...double check all assumptions.
1929 Model A Tudor Sedan
Eric Lewis is offline   Reply With Quote
Old 11-26-2017, 08:10 AM   #2
NCRebel
NCRebel's Avatar
Default Re: Removing Break Drums
I have a printed note on my tool/work bench that reads, "K. I. S. S." We all know what that stands for. I also have a note taped to my lawnmower (after modifying the fuel lines) that asks, "Gas off?"
I like your - double check all assumptions - idea.
NCRebel is offline   Reply With Quote
Old 11-26-2017, 08:11 AM   #3
JDupuis
JDupuis's Avatar
Lol. LMAO.. . Thanks Eric!
Great way to start my day.
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 11-26-2017, 11:13 AM   #4
100IH
How did the right rear come off with the e brake on ?
100IH is offline   Reply With Quote
Old 11-26-2017, 01:26 PM   #5
jax55
jax55's Avatar
That was my question as well, 100IH. Might be worth a look before things go back together.
jax55 is offline   Reply With Quote
Old 11-26-2017, 03:22 PM   #6
Eric Lewis
Eric Lewis's Avatar
My concern as well, something is correct between left and right e-brakes. We will see next week when I sit down to clean and inspect/adjust.
