Old 11-14-2017, 01:03 AM   #1
Chris Haynes
Chris Haynes's Avatar
Default MGB Shocks
I have installed the MGB Shocks on the front of my '30. The MGB shock arms were the same length as the stock A arms but needed a little tweaking. If I run the MGB shocks on the rear I will have to increase the length of the arm, not a big job. But I wonder if the shock will work correctly with more leverage from the longer arm?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 11-14-2017, 05:40 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: MGB Shocks
Originally Posted by Chris Haynes View Post
I have installed the MGB Shocks on the front of my '30. The MGB shock arms were the same length as the stock A arms. If I run the MGB shocks on the rear I will have to increase the length of the arm, not a big job. But I wonder if the shock will work correctly with more leverage from the longer arm?
It works fine. The Armstrong shock was designed so that you can install a higher viscosity oil if you need more dampening.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-14-2017, 02:07 PM   #3
Chris Haynes
Thank you.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-14-2017, 02:42 PM   #4
denis4x4
denis4x4's Avatar
I'm using MG Midget/Sprite rear shocks on the front axle of my Model A hot rod. Had the valving changed for better handling
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 11-14-2017, 02:48 PM   #5
Tim Ayers
Love the looks of these.
Old 11-14-2017, 02:59 PM   #6
BRENT in 10-uh-C
They'll polish up nicely too since they are aluminum.
BRENT in 10-uh-C
Old 11-14-2017, 03:13 PM   #7
hardtimes
hardtimes's Avatar
I agree that they look good. But, what a guy should be concerned about more, do they work good.
The answer, they work excellently. As a bonus, you can buy rebuilts right off of ebay and cheaply !!
hardtimes is offline   Reply With Quote
Old 11-14-2017, 03:42 PM   #8
Chuck Dempsey
Chuck Dempsey's Avatar
Is there a particular set of years of MGB/Sprite that fit the 'A'?
Thanks!
Chuck Dempsey is offline   Reply With Quote
Old 11-14-2017, 03:47 PM   #9
Tim Ayers
Sure, I guess I meant that without saying it. They seem like a better set-up than stock.
Old 11-14-2017, 04:32 PM   #10
Chris Haynes
Please tell me more about this.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-14-2017, 04:49 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
I had a MGB for many years, I learned to only buy new shocks, most of the rebuilds quit before the paint was dirty
Old 11-14-2017, 04:52 PM   #12
denis4x4
denis4x4's Avatar
These are the gurus of Armstrong shocks: http://www.nosimport.com/ Had them valved for hard down force and soft up force. You can also have them install a fill plug in the event you want to change the viscosity of the shock fluids.
Old 11-14-2017, 06:23 PM   #13
Hotrodfil
Hotrodfil's Avatar
I run MGB ones with the stock arm on the rear, but they hang too low on the front and hit the trackrod. How much clearance under the shock do you have Chris?
Hotrodfil is offline   Reply With Quote
Old 11-14-2017, 06:51 PM   #14
Tim Ayers
That's funny. Could you post a few links to who is selling new ones?
Old 11-14-2017, 07:26 PM   #15
CarlLaFong
CarlLaFong's Avatar
Moss Motors in Goleta, CA has new and rebuilt Armstrong Girling shocks
CarlLaFong is offline   Reply With Quote
Old 11-15-2017, 06:25 AM   #16
BRENT in 10-uh-C
I have good luck finding new (NORS) on eBay.
BRENT in 10-uh-C
Old 11-15-2017, 10:57 AM   #17
jax55
jax55's Avatar
Looks like a good way to go, if you (I) don't have the bucks to buy new A shocks.
My originals are toast, no way to just rebuild them.... so, what do I need to know to look for these MGB shocks?
Year and specific models? or just ask/ look for "MGB shocks"?
Thanks guys!
jax55 is offline   Reply With Quote
Old 11-20-2017, 07:59 PM   #18
jax55
jax55's Avatar
I guess this set up is a secret among those in the know. :-)) If anyone is willing to share the info we need to know about getting the proper shocks, please post it.
I appreciate your help!
Old 11-20-2017, 08:15 PM   #19
CarlLaFong
CarlLaFong's Avatar
I believe all MGB shocks, until BL went to the rubber bumpers, are the same. I was a parts man/manager at several British dealerships, but memories have faded, somewhat. The rear shocks are what you need, the fronts are built into the A arm and are unsuitable for a Model A. As I recall, the big Healey rear shocks have longer arms and could be the ticket for the rears on an A
Old 11-21-2017, 12:41 AM   #20
Floats
Floats's Avatar
Hi Guys,
The rear Armstrong lever arm dampers are all the same for British cars of the time. EXCEPT the shocks used on hevier cars had larger pistons or valves or whatever inside.
MG Midgets, Healey Sprites, MGS and the smaller dampers and the Big Healeys, TR4, 5 and 6 had the heavier ones. I might be mistaken but as I understand the shock bodies are the same but the inside bores are different.
I have just purchased a pair to fit on my 29 Chevy Phaeton.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
