10-25-2017, 07:52 AM | #1 |
Tiny hole
The throw out bearing has a tiny hole for grease. And have to go thru a small access hole to get to the bearing. What grease gun or applicator would it take to get in that small hole?
10-25-2017, 08:42 AM | #2 |
Re: Tiny hole
I use a grease gun with a 12" flexible hose between the pump and the tip.
I also have the adapter to fit the early Alemite fittings... Good Day! |
10-25-2017, 09:59 AM | #3 |
Re: Tiny hole
There should be a grease fitting in the hole. Is yours missing or are you talking about the hole in the fitting? Chances are you have a replacement bearing fitted and are only greasing between the bearing carrier and transmission input shaft. If you have modern style fittings on the rest of the car and original style in this location you will need to buy or barrow an adapter to grease it. The parts suppliers carry them.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 10-25-2017 at 10:06 AM. |
10-25-2017, 10:07 AM | #4 |
Re: Tiny hole
Grease needle?
10-25-2017, 07:38 PM | #5 |
Re: Tiny hole
Except for the AR,(early 28s Model A throughout bearings cannot be greased.) The fitting just greases the sliding shaft.
10-25-2017, 08:18 PM | #6 |
Re: Tiny hole
10-25-2017, 08:46 PM | #7 |
Re: Tiny hole
If your bearing has provisions to be lubed it will get the grease via the zirk fitting on the throughout collar. I have one like that. most newer throwout bearings come pre lubed and have no way to grease than by hand.
