Old 10-19-2017, 07:49 PM   #1
goshencars
Default 40 trunk wire routing
Having repaired the trunk area sheet metal I need a photo of where the wire for the license plate wire enters the trunk. When I started there was just a large hole. I know it on the left side and assume it to be behind the trunk side liner. Also does the tail light wires go thru any sheet metal or just go underneath?
goshencars is offline   Reply With Quote
