#1 |
Is there anything other than a head gasket leak that would cause the coolant to bubble?. Engine was just rebuilt this past year.
#2 |
cracks. Was it pressure tested before the rebuild? I would re-torque the heads and if that doesn't help might try a coolant sealer.
#3 |
and get it up near 200. Shut it down and let sit over night with the cap on tight. I have seen lots of bubble problems, water out the exhaust and it fixed 99% of the problems. I use the type with copper flakes. G.M.
www.fordcollector.com |
