#1 |
This is for the truck in the avatar, 1936, motor is a 1940, fresh rebuild, helmet distributor rebuilt by Bubba, 6V positive ground.
I ended up going back to a remote coil, Echlin IC7 with a FA54 condenser, no resistor in the circuit. I currently have the -6V from the ignition switch going to the + side of the coil and the - side of the coil going to the distributor. Do I have this backwards? The truck starts and runs fine up to about 30 MPH then doesn't have the power I think it should have. Carburetor has been rebuilt. Thoughts and suggestions much appreciated. Last edited by KDL; 10-16-2017 at 07:41 PM. |
