Old 10-14-2017, 03:45 PM   #1
adileo
adileo's Avatar
Default 52 f1 posi reverse eye front spring
Hi gents
I purchase posi reverse eye front spring for the 52 f1. Do I need to buy special shackles? One eye is up and other is down.
Do I need this:
File Type: jpg A6982DA7-5655-4417-8308-7609975F1425.jpg (6.7 KB, 14 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-14-2017, 07:06 PM   #2
Ken Crans
Ken Crans's Avatar
Default Re: 52 f1 posi reverse eye front spring
Put the reversed eye to the front, if turned around it will bind on shackle housing at the top. Also make sure when setting up caster and camber using the 2-7 degree wedges between springs and axle.
Ken Crans is offline   Reply With Quote
Old 10-14-2017, 07:13 PM   #3
adileo
adileo's Avatar
Thanks. Hard to tell from pic but that looks like regular shackles.
I don’t need the pic I inserted?
Thanks
Andy
1952 F1
Old 10-20-2017, 07:35 PM   #4
gearhead1952
gearhead1952's Avatar
Put those springs on my trucks. Just use the original ford shackles that came with truck.
gearhead1952 is offline   Reply With Quote
Old 10-20-2017, 08:02 PM   #5
adileo
adileo's Avatar
Thanks Gearhead. How you like them?
Thanks
Andy
1952 F1
