Old 09-27-2017, 05:00 AM   #1
Nigel
Default 28 mis fire
1928 Phaeton. I have a carby backfire issue. Have timed motor from TDC just put kit through 97 stromberg. I have good spark and fuel. Any body had similar issues? Could it be head gasket? I am a newbie as I inherited this beautiful car recently. It has a counter weight advance on distributed and apparently an upgraded coil.
Nigel is offline   Reply With Quote
Old 09-27-2017, 09:43 AM   #2
Smog Tech
Smog Tech's Avatar
Default Re: 28 mis fire
Are you using a fuel pump with your 97? The engine will idle and run slowly without a pump but will need a fuel pump for full power. All you need is 1 1/2 to 2 lbs. pressure.
Smog Tech is offline   Reply With Quote
Old 09-27-2017, 09:58 AM   #3
Jim Brierley
Check the fuel level in the carb. Main jets should be #45, idle screws should be all the way in, then out 1 - one and a half turns, adjust again with warm engine.
Jim Brierley is offline   Reply With Quote
