#1 |
I went to a local car show a few weeks ago and briefly talked to the owner of a blue '36 roadster (I think he's a member here).His flatty was supercharged and had cast brass heads.I've never seen or heard of them before and must be rare.Does anyone know anything about these heads? Just curious.
Thanks. |
#2 |
From the ones I've seen in photos over the years, they were used in marine applications.
#3 |
Federal Mogul had some called termo-flow.
Sure look different...and cost an arm and a leg... |
#4 |
Bronze actually, made by federal mogul. Pretty rare birds nowadays.
#5 |
Federal-Mogul made them. I believe they were a bronze alloy.
Cars are like potato chips, its hard to have just one. |
#6 |
#7 |
I don't remember seeing fins.The top surface was flat...I think.
#8 |
don't think they have any watr jackets??
#9 |
I've seen iron heads polished and brass plated, but that over 60 years ago.
I have a couple sets of Federal Mogul heads that are are cast bronze with aluminum tops, and they do have water passages. |
#10 |
I believe you will find them on the McGee roadster...one of the most iconic hot rods ever. I saw it being restored at the SoCal Speed shop and I don't think there were any water outlets. That's been years ago and my memory isn't what it used to be.
#11 |
Picture I posted has the water outlets, and Sidevalves picture has the ports for the water outlets. But, it does not appear they go through the entire head surface. Only a way to get the coolant out of the block into the radiator.
