Old 09-23-2017, 02:50 AM   #1
Questus
Questus's Avatar
Default Clutch shaft rubbing?
Good morning from Germany,
GERTRUD: FORD A Canada of June 1928, no - no longer a multi-disc clutch!
ASK:
Clutch and pressure plate have to be new at Gertrud, I am in the engine extension forward!
Is it then, when the engine is out, possible to re-disengage the clutch shaft?
There is game, I mean: can I good rub in the bell housing ?? because of space to the chassis left and right?
Do you have any tipps for my work ?
regards from QUESTUS 10:00 o`clock AM North europe
Questus is offline   Reply With Quote
