Old 09-16-2017, 12:15 PM   #1
BigDan
Default Heater bypass
My'46 heater core has sprung a leak. Since I store the car in winter , I'd like to just have the coolant bypass the heater but leave it in place under the dash. I see one hose going from the left lower radiator hose through the firewall to the heater and another coming through the firewall to a port on the opposite (driver's side) head. My plan is to join these two hoses under the hood or put shut-off valves on the engine side in both of them. Is either of these a viable solution? If not, does the heater need to come out and what does that involve? Thanks in advance for any comments, suggestions etc. I'm always grateful for the good advice that comes from the Barn.
Dan
BigDan is offline   Reply With Quote
Old 09-16-2017, 12:36 PM   #2
flathead48
Default Re: Heater bypass
Normally there is a shut off on the head that you close and that stops the water from circulating through the header.
flathead48 is offline   Reply With Quote
Old 09-16-2017, 02:02 PM   #3
oldford2
oldford2's Avatar
I believe there will still be water in the other hose and will be pressurized by whatever your radiator cap pressure is. Your idea to just join the 2 hoses should work and no need for shutoffs in them. JMO
John
oldford2 is offline   Reply With Quote
Old 09-16-2017, 02:16 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Any 5/8" dia. rod (metal,wood etc.) clamped in the tubes going to the heater to plug.
The water does not have to circulate.
When core is repaired, remove plugs and reassemble.
Old 09-16-2017, 04:10 PM   #5
BigDan
Smile Re: Heater bypass
Thanks guys!
Old 09-16-2017, 04:14 PM   #6
RKS.PA
RKS.PA's Avatar
The water flows from your lower right radiator hose through the heater and then back out of the heater into the head fitting. As noted above, I, too, have a shutoff at the head fitting. Just connect the input hose to the head fitting and let it circulate, with or without the shutoff closed.
Am running the one on my '47 like that now until I get the heater back in the car following engine and trans rebuild. (I needed to take the heater out to remove the floor pan.)
Dick.
RKS.PA is offline   Reply With Quote
