Old 09-15-2017, 07:57 PM   #1
Mlloyd
Mlloyd's Avatar
Default Runs rough
Last spring my1930 roadster started right up and ran well. Things happened that prevented driving it until now. Sounds terrible like it is running on two cylinders, however when I shorted the plugs with a screwdriver there is spark and a noticeable change on the sound. The plugs are new. I drained the tank, cleaned screen and sediment bowl. I've dismantled and cleaned the carburetor several times. Replaced the manifold gasket, and am stumped. There is black smoke coming from the tailpipe but it runs so poorly I can't get any adjustment done on the carb. Any thoughts?
Mlloyd is offline   Reply With Quote
Old 09-15-2017, 08:52 PM   #2
barnstuf
Default Re: Runs rough
I would suspect stale gas or stuck valves. Did you have stabilizer in the gas?
barnstuf is offline   Reply With Quote
Old 09-15-2017, 09:26 PM   #3
Mlloyd
Mlloyd's Avatar
Not this summer. Old gas was drained and replaced with fresh.
Old 09-15-2017, 10:50 PM   #4
Dick Steinkamp
Dick Steinkamp's Avatar
Running rich enough to generate black smoke?...I'd be looking for a stuck open needle and seat in the carb or a float with a hole in it.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 09-15-2017, 11:04 PM   #5
Paul Bennett
Almost sounds like you are one cylinder off on distributor cap with the screwdriver test. Engine gets enough spark to fire but not enough to run right, hence unburnt gas (black smoke).
Paul Bennett is offline   Reply With Quote
Old 09-15-2017, 11:40 PM   #6
mike657894
mike657894's Avatar
look at plugs to see which cyls are not firing. put a thumb over the hole and run the starter see if you have compression on dead cyl. if you do take some sand paper and clean up plug posts and bands. simple stuff first. black means your taking in a lot of gas that your not burning. you shouldn't have to change settings you haven't changed. you can look at the valves and run the starter to see if they move a stationary valve should be easy to spot.
mike657894 is offline   Reply With Quote
Old 09-16-2017, 01:33 AM   #7
H. L. Chauvin
First:
Make or think of a list of exactly what you touched or worked with since your Model A last ran with no problems:
If carburetor problems, and in looking at:
"I've dismantled and cleaned the carburetor several times."
Do you have a carburetor fuel level gauge, (Part No. 14680 in Bratton's on line catalog) to test to see if your bowl has too high a level of gasoline.
A. Maybe carburetor flat metal bowl tab is not be adjusted properly;
B. Bratton's Part #14300 series float valve could possibly be leaking gas in lieu of shutting off the supply of fuel when float rises.
C. Try placing carburetor float in a pan of boiling water .... if small air bubbles observed exiting bowl, bowl is leaking, not fully floating, and allowing too much gas in carburetor fuel bowl.
It always will be something so simple .... keep in touch.
H. L. Chauvin is offline   Reply With Quote
Old 09-16-2017, 03:51 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Point gap and cleanliness should be checked.
Old 09-16-2017, 09:11 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Is #4 spark jumping through the Dist Body, to #3 connector strap?
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-16-2017, 07:21 PM   #10
Mlloyd
Mlloyd's Avatar
A compression test shows 55lbs on each cylinder. Am I correct assuming that this indicates there is not a stuck valve?
Old 09-16-2017, 07:28 PM   #11
mike657894
mike657894's Avatar
yes it passes the comp test. a stuck valve will show 0 compression.
Old 09-17-2017, 04:21 AM   #12
ModelAMike1930
ModelAMike1930's Avatar
I would say its a carburetor problem. If you have a spare carb or can borrow one I would swap the carb out. It happened to me and I replaced the carb and it runs fine now.
ModelAMike1930 is offline   Reply With Quote
Old 09-17-2017, 04:27 AM   #13
pooch
pooch's Avatar
Rev it to about 1000 RPM and turn off the fuel tap and see if it comes clean for about 10 seconds before it runs out of gas.
pooch is offline   Reply With Quote
Old 09-17-2017, 05:21 AM   #14
Glen in Hillman MI
Is your GAV set proper? Close down all the way and open 1/2 turn.
Glen in Hillman MI is offline   Reply With Quote
Old 09-17-2017, 01:34 PM   #15
H. L. Chauvin
FWIW: Sometimes we all become obsessed with technicalities, precision, and whatnot & often ignore some of the most simple items that are overlooked.
"If" this engine ran and stumbled along with too much gas, (i.e., too rich a fuel mixture), and "if" you now have black foul plugs which are loaded with carbon, later substituting a perfect carburetor and a perfect distributor will not allow this engine to run smoothly & properly without first cleaning these plugs "if" loaded with carbon.
Old 09-17-2017, 02:25 PM   #16
Patrick L.
Patrick L.'s Avatar
It kinda sorta seems like a carburetor issue to me. Good compression and spark tend to lean toward fuel issues.
What does 'cleaned' the carburetor mean ? I don't mean anything by that, I'd just like to know what that means to you. Was the carb soaked ? Passages sprayed out and air blown thru them to make sure they are clear? Was float checked for leaks and proper height ? Is there the infamous 'dimple' in the float arm that may be causing the float to hang ?
The easy way to check is to use a known good carburetor if you have access to one. But, these don't take very long to go thru.
Old 09-17-2017, 04:36 PM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
Good easy quick test for a rich running cab, and this is what I would do first.
Don't touch anything to do with ignition yet.
