09-14-2017, 08:16 PM | #1 |
Exhaust manifold rejuvenation
I have the heater exhaust manifold, that I'm getting an ear repaired,and I would like to clean up the rust, and paint it with por15 manifold paint.
What's a good recommendation for the rust removal prep work.? |
09-14-2017, 08:20 PM | #2 |
Re: Exhaust manifold rejuvenation
sand blasting. I just blasted mine today and painted them (intake and exhaust) and the clamp and bolts with POR manifold paint.
09-14-2017, 09:35 PM | #3 |
yup - cast iron has a crapton of pores that wire brushing will never get clean. Bring a bunch of stuff to the blaster to make it worth while.
1929 Model AA - Need long splash aprons! |
09-15-2017, 05:18 AM | #4 |
Has anyone used CAST-BLAST paint? Vermins' has been "curing" for 3 years, I "think" it'll be OK!
Read of a Guy that SUPER HEATED his manifold, afterward, it showed LUMPS of LEAD or SOLDER like stuff all over it!!! "Wonder" what caused that????? Bill W.
09-15-2017, 08:26 AM | #5 |
The POR manifold paint has to be cured in the oven. 400 degrees for 4 hours. It's dry to the touch in a few minutes but will not perform properly unless oven cured.
09-15-2017, 08:44 AM | #6 |
09-15-2017, 09:09 AM | #7 |
Yes sandblasting will get all the rust out of the pores. Electrolysis would work well also
09-15-2017, 11:34 AM | #8 |
Sounds Great! However, what about the "Droop" or bend that manifolds acquire over time?This is where the manifold loses it's alignment with the last port and blows gaskets out. I think its usually at # 1 cylinder.
Terry |
09-16-2017, 06:34 PM | #9 | |
CRUSH a Viagra, mix it with water, brush it on the manifold, it "MAY" help Bill Usedtobedrooped
09-16-2017, 07:14 PM | #10 |
09-16-2017, 08:05 PM | #11 |
Bill - I use Cast Blast and like it.
First time I used it I cured it in the oven. Stunk the house up REALLY BAD! Very thankful my wife was out of town for a few days on a business trip. Won't do that again. Now I cure it by by evenly playing a torch over it until it gets good and hot.
Dave / Lincoln Nebraska |
09-16-2017, 08:21 PM | #12 | |
Hmmmmm, just reading this and truing to figure out how it relates to Bill's suggestion of Viagra. Don't think I really want to know. |
09-16-2017, 09:07 PM | #13 |
Post number 4
09-16-2017, 09:22 PM | #14 |
09-17-2017, 06:33 AM | #15 |
Heater manifolds are much less likely to "droop" than stock, non-heater manifolds. All the heater manifolds I have are straight as an arrow across all the exhaust ports.
