Old 08-30-2017, 11:07 PM   #1
Paul Bennett
Default Timing Light - Recommendations?
Many won't work on 6v requiring external 12v battery.
Battery 2 D Cell versions are available.
Some don't have a bright light but brightness isn't in the reviews.
What did you recently get and recommend? I'm close to pressing Start.
Please don't recommend something I can't buy today like your super MAC Pro from 30 years ago unless you are willing to sell it cheap.
My carb is due back soon and I've changed the coil I'm convinced was bad and replaced plugs, wires and cap. But it will need timing and my old timing light is dim and 12v only. I've already bought and returned the HF light.
Paul Bennett is offline   Reply With Quote
Old 08-30-2017, 11:14 PM   #2
Kahuna
Kahuna's Avatar
Default Re: Timing Light - Recommendations?
Paul
I'm also in need of a new light.
Looking forward to some good reviews.
My old light is/was a Craftsman, but not
available anymore.
Kahuna is offline   Reply With Quote
Old 08-30-2017, 11:27 PM   #3
Dave Castle
Dave Castle's Avatar
Electronic Specialties Model #130 , works on 6 or 12 volt, bright light, single lead.
Dave Castle is offline   Reply With Quote
Old 08-31-2017, 07:17 AM   #4
Capt Kirk
Capt Kirk's Avatar
If you can't find one that will work with 6 volts, you can hook a 12v light to a spare 12v battery and run it that way. I recently purchased one from AutoZone that shows RPM and has a timing advance button. I've been using it on my 56 which is 12v and it seems to work alright.
http://www.autozone.com/test-scan-an...ght/108152_0_0
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 08-31-2017, 08:32 AM   #5
D. Jones
D. Jones's Avatar
I power mine with a 12 volt power supply intended to run DC powered CB radios and similar things on AC power. Picked mine up at a yard sale. Another thought would be to look at the AC to DC power battery chargers that are used to charge different battery packs or run small items. I'm sure there must be one out there that puts out 12 volt DC at around 1 amp. I use a 6 volt one to charge my small motorcycle battery. Bought it for less than a dollar at a thrift shop.
D. Jones is offline   Reply With Quote
Old 08-31-2017, 10:02 AM   #6
corvette8n
corvette8n's Avatar
Whatever you end up with mark your pulleys with hard USA made blackboard chalk is has a Fluorescence quality to it.
Old 08-31-2017, 11:11 AM   #7
34fordy
34fordy's Avatar
A couple months ago, I bought an old Schauer 120 volt pencil timing light from roysboystoys on this site--It is more like a skinny flashlight--It is great for either 6 volt or 12 volt as it is powered by the 120 AC--It has an extremely bright light--Actually I bought it to hang on the wall as I thought it was kind of unique--No timing marks on my 34----Don
34fordy is offline   Reply With Quote
Old 08-31-2017, 12:10 PM   #8
51504bat
51504bat's Avatar
I've got this one that I listed for sale on the Barn a while ago.
https://www.fordbarn.com/forum/showthread.php?t=205581
I've still got it and I'll take $15.00 for it. I'll be in Oregon in early September and if you're interested we might be able to meet up and save shipping costs. PM me if you're interested.
Old 08-31-2017, 12:54 PM   #9
ursus
I see old 6-volt timing lights at swap meets for only a few dollars quite often. Check on E-Bay, they are very common and cheap because there isn't much demand. I found a barely used 1950's era Autolite 6-volt unit for only 5 bucks.
ursus is offline   Reply With Quote
Old 08-31-2017, 03:04 PM   #10
Paul Bennett
Found a #130 on eBay for $50 (MSRP $99) supposedly used once. Thanks all and Dave especially for the precise reply. Incidentally a friend mentioned renting a light just after I bought this one. OReilly's has free 3 day rental on tools.
Old 08-31-2017, 05:28 PM   #11
Capt Kirk
Capt Kirk's Avatar
I remember my dad having a timing light when I was a kid (we may still have it somewhere) that had two wires...one snapped onto the spark plug and the other snapped into the wire that was removed from that plug. Don't know what it was but do remember it working good on the 63 bug I was driving back then.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Old 08-31-2017, 05:57 PM   #12
JSeery
JSeery's Avatar
I have used the none external power lights.
Old 08-31-2017, 06:04 PM   #13
oldford2
oldford2's Avatar
I have a 12 volt battery and a 6 volt battery on my test stand. The 12 volt powers the starter (Helps a new engine spin) and my 12 volt timing light. The 6 volt is used for the ignition. Works fine for me.
John
oldford2 is offline   Reply With Quote
Old 08-31-2017, 09:29 PM   #14
Bubsyouruncle
I bought a timing light from Sears ages ago. 12volt negative ground.
It worked like a champ.
Cannot buy a timing light for 6 volt anymore.
Bought a 12/6v volt DC power supply on Amazon for $6+ and wired it up.
My old timing light works like a charm.
Bubsyouruncle is offline   Reply With Quote
Old 09-03-2017, 02:22 PM   #15
Flathead Fever
Flathead Fever's Avatar
I would not buy one unless it has the adjustable timing light feature so you can also check the total advance The initial timing is only the first step in checking timing. I just picked up a really nice one at an estate sale that was only used once by a neurosurgeon that died from brain a tumor. Sun timing lights were good. I'm not sure anybody makes good quality timing lights any more? Buying a used one is risky especially if they have been dropped.
Flathead Fever is offline   Reply With Quote
Old 09-03-2017, 05:18 PM   #16
Paul Bennett
Fever - I've not seen nor used a light with the adjustable feature. How do you use it...set the timing to the mark then what?
Old 09-03-2017, 06:39 PM   #17
flatjack9
flatjack9's Avatar
There is a dial on the timing light that you turn until the pointer lines u p with TDC and read the advance on the readout on the light.
Old 09-07-2017, 10:02 PM   #18
Bubsyouruncle
I had a 12V light from Sears ages ago. Didn't like 6volt positive ground. Bought a 12volt DC power supply from (It Shall Not Be Named) for 8 bucks. Works like a charm, and since it is 120v-12vdc powered, I can run it until ComEd goes out of business.
Old 09-07-2017, 10:10 PM   #19
Paul Bennett
My ESI 130 arrived today. Recall it uses D cells for power instead of connecting to the vehicle battery. Tried in on my daily driver and sorry to find the light is indeed weak in daylight. But I think it will be adequate for my garaged car. It sure got good reviews. Paid $57 eBay - MSRP is $99
Old 09-07-2017, 10:17 PM   #20
Alaska Jim
Alaska Jim's Avatar
I always use my 12 volt snap-on timing light. I hook the neg. and pos. leads to a spare 12 volt battery sitting on the floor next to my 51 Merc. ( still 6 volt ) and hook the spark plug lead to the Merc. the light does not care where the power is coming from, only that the spark plug clamp is on #1 plug wire. The timing light is the dial back adjustable type.----Jim
Alaska Jim is offline   Reply With Quote
