Old 08-30-2017, 05:15 PM   #1
David31dlxslant
David31dlxslant's Avatar
Default Attention! Slant windshield 4 door owners! Needing advise!
Hello all, I've got a 31 Slant 4 door town sedan, the outside door handles sag, who offers a rebuild kit? Springs? Etc etc to rebuild the door mechanism to bring the outside door handles back to original? I called brattons and they have kits but they're technically not for slant windshield model a's, my RR door is the worst, it saga about 2 inches, Thanks for any help
David31dlxslant is offline   Reply With Quote
Old 08-30-2017, 05:35 PM   #2
jw hash
jw hash's Avatar
Default Re: Attention! Slant windshield 4 door owners! Needing advise!
first of all, NO ONE makes a rebuild kit for the S/W door latches. and no one makes a good spring for the remote. that I have found. the 32 ford door latches use the same springs. I rebuild a lot of these latches and I`m currently out of latches and the main springs. I make the rivets on the lathe. I will be at Hershey this year, so hopefully I can find some. it could be your latch is twisted inside. that happens when someone tries to open door when it is locked on the inside. it is pretty common.
jw hash is offline   Reply With Quote
Old 08-30-2017, 07:12 PM   #3
Kevin in NJ
Follow the link to my web page below.
You have to rebuild by taking them apart and welding up the wear. Pretty easy.
Kevin in NJ is offline   Reply With Quote
Old 08-30-2017, 07:36 PM   #4
Oldbluoval
Oldbluoval's Avatar
There is also a brass bushing that has the square hole for the handle that gets worn. It then twists and let's the handle droop
I am in signal Mtn and 30 miles from you
I have done dozens of those
Oldbluoval is offline   Reply With Quote
Old 08-31-2017, 08:16 PM   #5
brianpharmd
brianpharmd's Avatar
I had Oldbluoval rebuild my latches. They work great. Steve at Bert's recommended a vice and heat to bend the shaft on the passenger door handle back to "preceved" normal. As you figure out the angle of sag and then heat/bend the shaft to "reset" normal.
brianpharmd is offline   Reply With Quote
Old 09-01-2017, 11:02 AM   #6
duke36
I've done as Brian in post 5 and JW in post 2 suggest for many car makes. Works fine as long as the rotation back to "normal" is not too severe.
duke36 is offline   Reply With Quote
