Old 12-10-2010, 08:13 PM   #1
Tinbasher
Tinbasher's Avatar
Unhappy 30 Coupe Top Bow placement
Evening guys: I'll try again, does anyone know the measurements betwen the top bows on a 30 Coupe. I'm starting to put the body back together and I need the measurements as someone in the past has made up new top wood but they didn't mark or cut out the side rails for the bows. Help, Help, Help!!!
J.Poole The Old Tinbasher
Tinbasher is offline   Reply With Quote
Old 12-10-2010, 08:17 PM   #2
Grapejuice
Grapejuice's Avatar
Default Re: 30 Coupe Top Bow placement
Why not just buy a top wood kit pre cut and replace all of it?
Alan
1930 Cabriolet (the newest project)
1929 Special Coupe (pieces n parts)
1928 Sport Coupe (the driver)
Grapejuice is offline   Reply With Quote
Old 12-10-2010, 08:28 PM   #3
Tinbasher
Tinbasher's Avatar
Not a bad Idea if I get stuck. (The wood is all new, but made up by the last owner)
JP
Old 12-10-2010, 08:53 PM   #4
brum1
brum1's Avatar
Tinbasher,
I am currently installing a wood kit on my 30 coupe, If you can be more specific on the dimension you need I can measure tomorro and respond (front to back, center of mounting screws?)
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 12-13-2010, 07:39 PM   #5
Tinbasher
Tinbasher's Avatar
If you could give me the lenght from the rear edge of the windshield header to the centre of the front bow and then the distance between the centres of the remaining bows that would be great. That will get the job done.
Thank you for your time. J.Poole "The Old Tinbasher"
Old 12-14-2010, 03:26 AM   #6
brum1
brum1's Avatar
Tinbasher,
Can do, out of the country at the moment, will return by weekend,
Regards,
Old 12-14-2010, 08:30 AM   #7
LeRoycoupe/N.Y.
Tinbasher
This could help,Front header to rear 36", Front header to middle of bolt(driver side)1 & 1/4.First bow 7 &1/8.Second Bow14 &1/2,Third bow 22 & 1/2, Fourth bow 31 & &1/4. This is my 31 coupe.Same measurement for passenger side.---LeRoy,
LeRoycoupe/N.Y. is offline   Reply With Quote
Old 12-17-2010, 03:37 PM   #8
Tinbasher
Tinbasher's Avatar
Thanks LeRoy: Your a life saver. Apprieciate the help.
If your into metal work, Email me with your address and I`ll send you out a copy of my Sheet Metal repair book. tinbasher at rogers.com (for some reason my At isn`t working!!!!)
J.Poole
Old 12-18-2010, 07:54 AM   #9
brum1
brum1's Avatar
Tinbasher,
Lay the bows in place on a brand new wood kit (30 Coupe) and I measure the following:
Front header back edge to first bow center: 7-1/2"
1st bow center to 2nd bow center: 7-1/2"
2nd bow center to 3rd bow center: 8-1/4"
3rd bow center to 4th bow center: 8-1/2"
Old 12-18-2010, 07:56 AM   #10
1931 flamingo
1931 flamingo's Avatar
Actually, if you're going to upholster, doesn't matter where you put them. If it was me would probably space them out evenly. If covered, no one but you will know they're not "authentic". JMO
paul in CT
