08-22-2017, 04:47 PM | #1 |
Wheel studs
Can anyone tell me where I can get the right wheel studs for a 48 passenger car. I ordered some from Joblot before they went out of business and the shoulder is to long, wheel won't draw tight to drum. Thanks
08-22-2017, 05:30 PM | #2 |
Re: Wheel studs
I am sorting studs at moment for some customers. Give me a call for your measurements. 507-332-6789 Fred
08-23-2017, 06:20 AM | #3 |
Re: Wheel studs
NAPA machined off some of the shoulder on mine.
08-23-2017, 06:46 AM | #4 |
Re: Wheel studs
Thanks for your reply, I thought of that but was not sure there would be enought threads holding. Will try it thanks again,
08-23-2017, 11:02 AM | #5 |
Re: Wheel studs
May have some . Post dimensions .
08-23-2017, 11:33 AM | #6 |
Re: Wheel studs
08-23-2017, 12:16 PM | #7 |
Re: Wheel studs
I found some usable studs when I did a Buick drum conversion. Everything was fine but the serrations were too long. I flattened some lockwashers and put them under the heads and all fit fine. I wish I could give you the numbers but the parts were sold.
08-23-2017, 12:50 PM | #8 |
Re: Wheel studs
Yes I do, thanks
08-23-2017, 12:54 PM | #9 |
Re: Wheel studs
I think I will follow corvette suggestion and machine off about 3/32 of the shoulder. Thanks to everyone who took the time to help. Rick
08-23-2017, 12:59 PM | #10 |
Re: Wheel studs
I'm curious to understand how you were able to swage them PROPERLY with the shoulder being too long. DD
08-23-2017, 02:05 PM | #11 |
Re: Wheel studs
I did not do anything with them, was looking for studs with shorter shoulder.
08-23-2017, 02:35 PM | #12 |
Re: Wheel studs
I looked in the green book and it shows the shoulder between .43" and .51" of the
different studs. Bob |
08-23-2017, 02:51 PM | #13 |
Re: Wheel studs
Bob C, the book shows 3 different sizes for 40-48. No one shows .43, have found .47, will try that one thanks for your input.
08-23-2017, 04:34 PM | #14 |
Re: Wheel studs
The right studs are out there. Got mine from the late Dick Spadaro. No swagging involved.
08-23-2017, 04:48 PM | #15 |
Re: Wheel studs
08-23-2017, 07:05 PM | #16 |
Re: Wheel studs
Bob, I think the 51A- 1107 for the front would work. Thanks to all you guys that go out of your way to help, it is really appreciated.
