#1 |
I've read and heard that the correct '33-'36 fuel pump should have a pressure of 2.5 to 3 PSI. I tested the pumps I have for my '34 and they ranged from 3.5 to 5 PSI. I have had some carb issues (leaks) that may be caused by a too high pump PSI. Where can I get fuel pumps with the correct PSI? Does any one rebuild them with the correct pressure. Happy V8ing, Mike
#2 | |
Buy a good low pressure regulator and gauge . That's all you need!! Sent from my iPad using Tapatalk |
#3 |
How did you check the out-put pressure? Did you put a gauge in between the fuel pump and the carb. I've been wanting to check miine, but so busy fixing other problems haven't got a round-tuit. When my new gas tank get's here maybe I can do that next, I think mine is too low or pump is bad. Al
#4 | |
Super Moderator
Yes, you could install a regulator but by your post, it sounds as if you prefer to do things correctly vs. installing a (regulator) bandage in-between. Charlie is a great guy, does great work at a reasonable cost. You'll enjoy working with him...
#5 |
I put a 0 to 5 Psi gauge between the fuel pump and the carb. Mike
#6 | |
#7 | |
https://www.fordbarn.com/forum/priva...o=newpm&u=1147 Last edited by V8COOPMAN; 08-19-2017 at 06:59 PM. |
#8 |
Uh, Oh...looks like Charlie is driving a Chevy!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
#9 | |
Softer spring is what is needed for a lower pressure. |
#10 |
I had the same problem and fitted the oldest spring I could find into the new pump. That did the trick.
Mart. |
#11 |
For my money and the great work he does, Charlie can drive anything he wants!!! Great pic. Coop, of Charlie and his lovely wife, Alice!!
Dick. |
#12 |
He did a great job on my'32 Plymouth PB fuel pump that you cannot buy anywhere even in core form very tough and also the Carter updraft carburetor rebuild.Car runs great now and good to be off electric fuel pump on the updraft.So he is not just good on solely Ford Flathead parts.
"Never complain,never explain"... Henry Ford II |
#13 | |
On the fuel pump subject, I came across these this morning. The red wire-tie puts a smile on my face, cuz I know those are from Charlie NY. PS I have a photo just like the one above, but from Hershey. One of my favorites. Good folks!
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 08-20-2017 at 09:36 AM. |
#14 |
But judging by his sweatshirt he has good taste in beer!
Making the simple complicated for over 30 years. |
#15 |
Charlie ain't no dummy! He knows the best of the old, as well as of the newer. DD
#16 |
Charlie the man , class act and stands behind his work.Fast turn around.
#17 |
when you change your pump take the spring out put it in the new pump. why spend money for shipping back & forth plus labor it,s a simple task to change the spring
