Old 08-18-2017, 08:04 PM   #1
DD931
DD931's Avatar
Default How to paint a raised surface
I'm looking for advice on how to paint a raised surface - the challenge is an aftermarket radio with raised letters on the plastic faceplate. The letters need to be painted. The faceplate is off the radio and is flat. Tight nap roller? Some sort of felt rig? How about laying down a coat of paint on a piece of cardboard that you lightly dip the piece into/onto? Of course my fear is applying too much paint and having a crappy mess when I'm done. I'm out of ideas and was hoping to gain from others mistakes before I have to learn it all the hard way!! Thanks for any help you all can offer!!!
DD931 is offline   Reply With Quote
Old 08-18-2017, 08:24 PM   #2
Capt Kirk
Capt Kirk's Avatar
Default Re: How to paint a raised surface
I have zero experience in what you're wanting to do but just reasoning through this, I'd think that you don't want anything with a "nap". Flat hard surface with a thin coat of wet paint on it then press your part onto it. Guessing first try may not get full coverage...wait till tacky and repeat. Minimum paint on the surface and multiple coats would be what I'd do.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 08-18-2017, 08:26 PM   #3
Charlie Stephens
Stores that specialize in "art" supplies (or maybe children's craft supplies) may have a rubber roller that would work. Especially true if you could use black ink.
Charlie Stephens
Old 08-18-2017, 08:44 PM   #4
FlatheadTed
FlatheadTed's Avatar
Rubber roller X 2
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-18-2017, 10:22 PM   #5
Ross F-1
Ross F-1's Avatar
I've tried the rubber rollers on larger pieces. You've got to have something to hold the roller "flat" and at the correct depth for a chance of success. Getting the correct amount of ink/paint on the roller, and the right viscosity, is another challenge.
There is a gum rubber product sold at art supply stores that brushes on and dries, so you can mask the sides of the raised letters. The gum then can be peeled off.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-18-2017, 10:23 PM   #6
Lawson Cox
Lawson Cox's Avatar
You probably will have to use a printer's ink. Paint on a roller will lift part of the paint and leave little stringy thingies that will make a mess. I've tried it and that's what happened to me trying to roll on painted numbers on a license plate. I ended up painting the whole thing the color of the raised letters, then painting the background color and compounding off the raised letters to reveal the color of the letters. My 2¢.
Old 08-18-2017, 11:01 PM   #7
Vics Stuff
Vics Stuff's Avatar
Take your paint that you are going to use and apply a thin coat on a piece of glass. While the paint is wet , take your part and lay it down on the glass. Immediately lift straight up to prevent runs off to one side or the other. I would recommend to also reduce the paint about 10%. This will allow the paint to cover the lettering well. You may need to do this several times in between allowing paint to dry.
Have don it many times with great results.
Vic
Vics Stuff is offline   Reply With Quote
Old 08-18-2017, 11:46 PM   #8
ford38v8
ford38v8's Avatar
As others have advised, Hobby shops carry small, soft rubber rollers, and also have Testors model airplane paint, which works very well with the roller they sell. One stop shopping!
This method is also the best way to paint the (gold) Ford Script on 6V batteries.
Alan
Old 08-19-2017, 12:12 AM   #9
outlaw
There are paint pens available at hardware stores. I have seen red, yellow, silver, white, black, green, & purple that I can think of. We use these at work. Lumber yards also carry a paint marker referred to as a lumber crayon. Sharpies also come in various colors & work well for this. Also napa & carquest amongst others should have automotive touch up paint pens in a multitude of automotive colors to choose from. This would be the easiest way that I know to re color your letters. I just did this on a Kohler 8hp motor. The motor color is red & the letters needed to be silver. It's just like using a crayon. Just my opinion. Bill
outlaw is offline   Reply With Quote
Old 08-19-2017, 10:55 AM   #10
cmbrucew
cmbrucew's Avatar
Buy nail polish at the dollar store, they come with a brush. If your hand is not steady, take the panel to a nails shop and have them do it.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-19-2017, 11:02 AM   #11
DD931
DD931's Avatar
Thanks for all the suggestions!!
Old 08-19-2017, 11:12 AM   #12
grumppyoldman
grumppyoldman's Avatar
I like what CM said, go to nail shop, look at pretty girls while they paint your letter's.Al
grumppyoldman is offline   Reply With Quote
Old 08-19-2017, 11:14 AM   #13
Merc Cruzer
Merc Cruzer's Avatar
Vic
Vic is correct. I use painter "One Shot" I comes in numerous colors and I roll the paint on the glass until it becomes sticky, then roll the surface you want painted.
Merc Cruzer is offline   Reply With Quote
Old 08-19-2017, 04:58 PM   #14
Fibber Mcgee
Fibber Mcgee's Avatar
I don't know if it will work for this but I know for license tags I've seen people fill the low areas with water leaving just the numbers exposed and then spray paint it. Maybe you could submerge the faceplate leaving only the letters exposed and paint it.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 08-19-2017, 06:31 PM   #15
hotcoupe
hotcoupe's Avatar
I would advise you to go to an art supply and get a "brayer". It is a rubber roller, made to do exactly what you are attempting to do. Use a sheet of glass to evenly load the brayer with material.
Hope this helps,
Tom
hotcoupe is offline   Reply With Quote
Old 08-20-2017, 08:03 AM   #16
stangblue
stangblue's Avatar
My .02 I would try to put a track (guide) on either side of the faceplate the same the same height (or a hair less or higher depends on coating) as the letters. numbers. Then using the rubber roller to apply coating.
Assumption is the mother of all foul-ups.
stangblue is offline   Reply With Quote
Old 08-20-2017, 08:53 AM   #17
Planojc
Planojc's Avatar
Merc Cruzer has it right. You can get the roller at Hobby Lobby. I've done many license plates this way.
Planojc is offline   Reply With Quote
Old 08-20-2017, 09:53 AM   #18
DD931
DD931's Avatar
Consensus seems to be the roller with a sheet of glass. I'll let you all know how it works!! Thanks again for all the help!!
