Old 08-16-2017, 10:55 AM   #1
V12Bill
V12Bill's Avatar
Default Removing ignition switch on F1
I need to remove the ignition switch on my 1950 Ford F1. I have looked it over and see no pins to push or pull nor nuts or bolts to loosen. How does this thing come out?? Google, you tube, nor other forums have any advice on it's removal. Can any one out there set me on the right trail to a solution??
V12Bill is offline   Reply With Quote
Old 08-16-2017, 11:33 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Removing ignition switch on F1
If I'm not mistaken it comes out the same as a '50 Merc.
Push the switch from under the dash towards the rear of the truck (it is spring loaded)
Then rotate the bezel to disengage.
Old 08-16-2017, 01:15 PM   #3
1948F-1Pickup
1948F-1Pickup's Avatar
I concur. I think I recall that was the operation.
There is absolutely no direction outlined on the web.
(I discovered that truth when I went to remove my
F-1 switch a few months back)
1948F-1Pickup is offline   Reply With Quote
Old 08-16-2017, 02:45 PM   #4
DD931
DD931's Avatar
Snap off the bezel and then push the switch against the spring and turn to free the bayonet attachment scheme.
DD931 is offline   Reply With Quote
Old 08-16-2017, 03:59 PM   #5
V12Bill
V12Bill's Avatar
Got it out! Pry off bezel, turn ignition switch 1/8 turn clockwise (as seated behind the wheel).
Old 08-16-2017, 04:10 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Success
Old 08-16-2017, 08:19 PM   #7
DD931
DD931's Avatar
I love a happy ending!!
Old 07-16-2024, 09:54 PM   #8
tyd_76
Good evening…thank you all for the information, as V12Bill stated there is nothing out there on info to remove. I’ve been searching all day non stop. Finally, came across this thread and here’s the info. I appreciate it very much. 1950 Mercury. Stay safe, blessed, and be well.
tyd_76 is offline   Reply With Quote
