07-28-2017, 04:39 PM | #1 |
59 flathead JB weld or weld crack
Started on a new project and was cleaning up a 59 block and found a small crack .
I hear some folks mention using JB weld in lieu of welding ... See photo. Any thoughts on this minor crack ..... Thanks
"I can't cry as long as I know the Lord has risen " |
07-28-2017, 05:01 PM | #2 |
Re: 59 flathead JB weld or weld crack
Just ignore it! 99% of all blocks have those, commonly referred to as part number cracks, as in they should have a part number ascribed to them. Will not cause any bother.
07-28-2017, 05:02 PM | #3 |
My 8BA bock has several of those. I chose to ignore them. Doesn't leak.
Barry 50 F-1 |
07-28-2017, 06:11 PM | #4 |
Thanks guys
07-29-2017, 10:46 AM | #5 |
From the pix I would assume that the crack is adjacent to a head bolt and a coolant passage. I agree that it will most likely never cause a problem, however, I would suggest that you use a thread sealant on the stud.
Bill.... 36 5 win cpe |
07-29-2017, 04:21 PM | #6 |
07-29-2017, 04:29 PM | #7 |
There's only one crack like that? Consider yourself very fortunate!
07-29-2017, 05:07 PM | #8 |
Over here that is real a good one...the save for a much much later repair way way out in the yard would scare the daylight out of you if that block worries you
