Old 07-27-2017, 01:31 PM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default I test drove the 32 today Not good
I drove the 32 about 3 blocks and on a state road to see how it handled. I got a bad shimmy or a death wobble as some call it I had to come to a stop to stop it. I drove slow back to the garage. It scared me a bit never had that happen before for a long time ago in a Model A. I jack up the front end and it seams tight but I know there a problem some where in the front end. King pins are tight no play there. Almost need two people to find the problem One watching the tie rod to see if there play and someone moving the wheel. Any of you had this problem? What was the cure.
Old Redneck is offline   Reply With Quote
Old 07-27-2017, 01:38 PM   #2
DavidG
DavidG's Avatar
Default Re: I test drove the 32 today Not good
Could be too much play between your steering sector and worm gears or worn drag link/spindle ball studs, springs, and plug ends.
Old 07-27-2017, 01:39 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Can you post some pictures of the front axle and spindles, tie rod and drag link where it meets the Pitman arm? Some build details about the front suspension and the chassis in general surely couldn't hurt, either. Assuming this is the cool little coupe you speak of. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-27-2017, 02:08 PM   #4
1931 flamingo
1931 flamingo's Avatar
Loose wish bone ball, loose pitman arm, loose/worn tie rods, drag link, loose wheel bearings.
Yes, probably two people needed. Start at the pitman arm and work forward.
Paul in CT
Old 07-27-2017, 02:14 PM   #5
Seth Swoboda
Seth Swoboda's Avatar
Redneck, if you adopt me I will drive out to your place and make the repairs.
Seth Swoboda is offline   Reply With Quote
Old 07-27-2017, 02:15 PM   #6
48fordnut
48fordnut's Avatar
Had the same problem. New vega box, tried every thing, found the vega box needed to be adjusted. Cured it in just a few min.
48fordnut is offline   Reply With Quote
Old 07-27-2017, 02:18 PM   #7
Joe31
Joe31's Avatar
I have had 3 cars over the years with death wobble. front tires all 3 times. joe
Joe31 is offline   Reply With Quote
Old 07-27-2017, 02:19 PM   #8
KiWinUS
KiWinUS's Avatar
No caster
Old 07-27-2017, 02:35 PM   #9
Old Redneck
So far I repack the wheel bear
ing in the front wheels and tighten the wheels. The front end seams tight. Now to check the wishbone. Time for a break. anyway I am hungry.
Old 07-27-2017, 02:43 PM   #10
Mart
Mart's Avatar
it doesn't like the camber on the state road. It needs to be driven on the left side of the road.
Ship it to me and I'll tell you if it still does it.
Nice looking coupe, by the way.
My roadster does it occasionally. I just either slow until it stops or (takes nerve) accelerate until it stops. There is normally a critical speed band that it may occur at. A slight bump when at that speed can set it off.
If there is nothing obviously wrong, give it another go, but try and go straight to a speed above that at which the problem occurred.
Mart.
Old 07-27-2017, 04:40 PM   #11
Old Redneck
My 33 ford never did this. I have had several Model A's and when I got my first Model A it did this. I fix the wishbone ball and that took care of it. That next on the 32 to check out.
Old 07-27-2017, 04:50 PM   #12
B-O-B
B-O-B's Avatar
Redneck check your rims for a bent one. Had that on a 56 ford truck changed the wheel & problem solved. Bias ply tires are not the greatest either. You already know that tho.
B-O-B
B-O-B is offline   Reply With Quote
Old 07-27-2017, 04:50 PM   #13
Ian NZ
Ian NZ's Avatar
My original 32 with the original 18" wheels runs great even at 60 mph. I have the original steering box with 1934, 15 -1 internals, check castor.
Ian NZ is offline   Reply With Quote
Old 07-27-2017, 05:01 PM   #14
weemark
surely on a stock car the castor angle cannot be changed from whatever it is?
weemark is offline   Reply With Quote
Old 07-27-2017, 05:17 PM   #15
JSeery
JSeery's Avatar
It can be changed by accident or deliberately. Originally alignment shops had the equipment to bend the axles, now days only truck shops would have the correct setup to bend the axles around. In the Hot Rod world you can change the castor by making pie cuts in the wishbones.
Old 07-27-2017, 05:23 PM   #16
weemark
yes I agree that the castor angle can be changed by cutting the wishbones but that wouldn't be a stock set up then...
I wouldn't have thought about checking the axle for straightness, given the age of them I guess it would be worth checking.
Old 07-27-2017, 06:13 PM   #17
JSeery
JSeery's Avatar
This is not an early axle, but same process.
Old 07-27-2017, 06:24 PM   #18
Ford Freak
How far can you turn the steering wheel ( slop ) before it turns the front wheels left or right ?
Ford Freak is offline   Reply With Quote
Old 07-27-2017, 06:45 PM   #19
vulture
vulture's Avatar
Mr Redneck check to see air pressure in the tires and if you can Jack up the front end and spin the tires. Also check your toe in at that time and see how tight it is up in the air with no load. You have a beautiful car and I am sure it is something simple
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
Old 07-27-2017, 06:49 PM   #20
TJ
TJ's Avatar
How old are your tires?
