Old 06-24-2017, 07:43 AM   #1
Jakno
Jakno's Avatar
Default Radial Tire Clearance 35 pickup
We are installing four new 225/75R16 radial tires on 35 pickup. Rears fit fine, plenty of clearance. The front tire/fender clearance, not so good. Have approx. 3/8" of clearance to front lip of fender which causes tire to rub when turning.
I have been planning on converting the front shocks to the tube type which I'm hoping will give me some front end lift ?.
Has anyone experienced this problem with a successful solution they would share ?. Thanks
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 06-24-2017, 07:54 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Radial Tire Clearance 35 pickup
Weak front spring?? Have you lowered the front end ie: dropped axle??
Paul in CT
Old 06-24-2017, 08:11 AM   #3
Jakno
Jakno's Avatar
Paul, haven't changed anything from the stock front end. Had the original shocks re-built but am not confident they came back close to original. I will check the front spring and bushings for cracks and wear. Don't find replacement springs for 35 pickup listed.. Thanks
Old 06-24-2017, 08:23 AM   #4
Flat Ernie
Flat Ernie's Avatar
Springs and components should be same as passenger car...
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 06-24-2017, 08:36 AM   #5
Jeff/Illinois
Jeff/Illinois's Avatar
Nice looking tires.
Our 650/16 bias tires don't even look quite that big, and they take up plenty of room on our '36 Pickup
Jeff/Illinois is offline   Reply With Quote
Old 06-24-2017, 09:21 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Installing tube type shocks wont lift anything unless they are air shocks.
Instead of the oversize radials a smaller tire should have been considered.
Old 06-24-2017, 10:01 AM   #7
Scott/Mn
Scott/Mn's Avatar
Janko, does your truck have the stock '35 Ford wheels? I am considering installing radials on my '34 pickup (has '35 spoke wheels); 215-70/16 size has been recommended to me. However I am thinking mine may have smaller wheel wells.
Scott/Mn is offline   Reply With Quote
Old 06-24-2017, 10:24 AM   #8
Jakno
Jakno's Avatar
Originally Posted by Scott/Mn View Post
Janko, does your truck have the stock '35 Ford wheels? I am considering installing radials on my '34 pickup (has '35 spoke wheels); 215-70/16 size has been recommended to me. However I am thinking mine may have smaller fender wells.
My wheels are the stock 1935, 4.5 " rims I believe
Old 06-24-2017, 10:37 AM   #9
42merc
42merc's Avatar
225-75x16 are too large for the front end of any pre war Ford. I would think a tire about 26" tall should be a better fit.
Go to any tire site & check the specs for dimensions.
42merc is offline   Reply With Quote
Old 06-24-2017, 11:30 AM   #10
Jakno
Jakno's Avatar
Originally Posted by Jeff/Illinois View Post
Nice looking tires.
According to the tire chart conversion list I'm using, the 650-16 tire compares in height ( 29.3") to a 225/75R16 tire. My problem is not really the height, it's the width of approx. 8.5 ".
Old 06-25-2017, 09:37 AM   #11
dude
dude's Avatar
Originally Posted by 51 merc-ct View Post
installing tube type shocks wont lift anything unless they are air shocks.
2x ,
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 06-25-2017, 10:52 AM   #12
51 MERC-CT
51 MERC-CT's Avatar
"Stock 1935, 4.5 " rims I believe"?
Most if not all radials in the size range you are using require a minimum of 5.5" rim width.
Also thought that stock '35 tires were 600/16 and not 650/16 which you used to figure the size you needed.
And that would reduce the dia. by an inch.
Old 06-25-2017, 12:28 PM   #13
Lawson Cox
Lawson Cox's Avatar
I have 650 x 16 Goodyear's on the front of my truck and they are really tall, run with no problems. I do have a sway bar, however. Tires are close to fender, but no rubbing, e en on hard turns.
Old 06-25-2017, 12:42 PM   #14
TJ
TJ's Avatar
Stock 35 rims are only 4" wide. Not wide enough for the size of tire you have mounted. Do you have stock brakes or hydraulics? I think the hydraulics may move you wheel outboard slightly putting you closer to the fender. Is it possible you have a later axle under the car? The later axles are wider.
Old 06-25-2017, 01:00 PM   #15
Lawson Cox
Lawson Cox's Avatar
If this posting is in response to my post above, Yes, I do have hydraulics, with stock axel and 39 backing plates.
Old 06-25-2017, 01:01 PM   #16
JSeery
JSeery's Avatar
Maybe it's just me, but why would you want big tires on the front? Car/Trucks look better with big on the back and smaller on the front.
Old 06-25-2017, 02:48 PM   #17
Jakno
Jakno's Avatar
Like Lawson, I do have Hyd brakes and stock axle. If I have to go with smaller front tires, we'll do that. I like all the tires the same size, it looks like what Henry intended it to be , a truck.
Thanks for everyone's help and idea's .
Old 06-27-2017, 03:20 AM   #18
tub1
tub1's Avatar
I'm thinking if you have a later axle under your pick up you would be better off 37 to 40 axles are narrower than 35 ones , to install later axle you need wishbones and all parts
tub1 is offline   Reply With Quote
Old 06-27-2017, 04:45 AM   #19
Mart
Mart's Avatar
^^ Good point above, (I thought tub was talking rear axles, but no, he's right, the front axles are narrower).
I have some experience of this, if you put 37 spindles and hydraulic brakes onto an earlier axle, and then use wires,(and the associated thin support spacers) you do increase the track width.
But the reality is that the tyres are too wide. a 205 16 is narrower and plenty tall, but that is also too wide (imho).
I don't know if a 195 16 is available, but that would be more appropriate for the front of your truck.
Or some 600-16's.
Mart.
Old 06-27-2017, 06:57 PM   #20
Talkwrench
Talkwrench's Avatar
No not just you ...
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
