Old 06-23-2017, 08:39 PM   #1
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default Help identify this u-bolt
I have a homemade trailer that has these u-bolts attaching the axle to the springs.
Any idea how I can find 3-4 more?
It appears to be 2 5/8" wide and 3 1/2" tall. The spring is 2".
Scott H in Wheaton is offline   Reply With Quote
Old 06-23-2017, 09:19 PM   #2
JSeery
JSeery's Avatar
Default Re: Help identify this u-bolt
Similar to some Ford spring u-bolts.
Old 06-23-2017, 09:22 PM   #3
Scott H in Wheaton
Agreed, but which one?
The axle appears to be early Ford front end, with the tie rod ends welded to a straight bar to prevent the spindles from moving.
Old 06-23-2017, 09:30 PM   #4
JSeery
JSeery's Avatar
37-41 looks close.
Old 06-23-2017, 09:42 PM   #5
Scott H in Wheaton
37-41 looks close.
Okay, those drawings help TREMENDOUSLY
I was measuring center to center
Inside edge to inside edge is more like 2.12 as Ford measures
