06-19-2017, 06:16 PM | #1 |
Part names
1949 ford has 2 part numbers that I need the description of. Part # 9025 & 9057. What are these? Thanks
06-19-2017, 06:40 PM | #2 |
Re: Part names
The part# 9057 in the earlier trucks (and school bus) was fuel tank hold down strap.
9025 doesn't show up in the "green bible" as it stops in 48. I believe the number is fuel system related. |
06-19-2017, 07:18 PM | #3 |
Re: Part names
If your working on a car 8A-9057 is the Fuel Tank Upper Support Assembly Front -LH.
9025 is not listed in the 1949-52 parts book. Like Deuce_roadster said it is part of the fuel system. It could be part of an assembly like a baffle in the fuel tank that would not be listed by itself but is part of the fuel tank assembly. Bob |
06-19-2017, 09:01 PM | #4 |
Re: Part names
Thanks for the info. where did you get the info from?
06-19-2017, 10:08 PM | #5 |
Re: Part names
1949-52 Ford parts book.
06-20-2017, 06:35 AM | #6 |
Re: Part names
Barry 50 F-1 |
06-21-2017, 09:04 AM | #7 |
Re: Part names
Could your number be 9052 which is the upper fuel tank support assembly.
