Old 06-06-2017, 08:39 PM   #1
Henry's Lady's Man
Henry's Lady's Man's Avatar
Default Engine bolts torques
I know it's come up before. Does anyone have a chart for proper torques on engine bolts? What I really need is the torque for the timing cover bolts. Les Andrews left this one out of his chart on page 1-134. I'm figuring 30 or 40 lbs? these are 9/16 bolts.
... prosperity is not the product of charity but of industry - HENRY FORD
Henry's Lady's Man is offline   Reply With Quote
Old 06-06-2017, 08:52 PM   #2
lindy williams
Default Re: Engine bolts torques
The timing cover bolts are 3/8-16. The maximum torque for this size bolt of grade 5 and thread is 39 lb.ft. So 35-40 would be appropriate.
lindy williams is offline   Reply With Quote
Old 06-06-2017, 08:57 PM   #3
Henry's Lady's Man
Thanks
Old 06-06-2017, 11:35 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Some timing cover bolt holes extend into the timing gear areas. Put #2 PERMATEX on those bolt threads, or oil will spiral around those threads & LEAK out from the lockwasher slit!
Bill Drip
"THE ASSISTANT GURU OF STUFF"
Old 06-07-2017, 12:30 AM   #5
H. L. Chauvin
Mr. Andrews has a detailed "Bolt-Grade/Torque Comparison Chart" for different SAE grades of bolts, with different threads per inch, at the very end of his Handbook, (in the Appendix, page A-4), with torque reduction percentage amounts for commonly used Model A lubricants.
H. L. Chauvin is offline   Reply With Quote
