Old 06-05-2017, 04:56 PM   #1
duke36
Default Destroyed fuel hose
Just replaced 2 yr old piece of fuel rated hose at the shop in '32 non ford product. Another "modern" gas episode--- to be replaced with metal gas lines, etc.
Now we're paying more close attention to gauges, valves, filters, seals and gaskets.
duke36 is offline   Reply With Quote
Old 06-05-2017, 05:43 PM   #2
Bill in SoCal
Bill in SoCal's Avatar
Default Re: Destroyed fuel hose
Ethanol?
Bill in SoCal is offline   Reply With Quote
Old 06-05-2017, 07:18 PM   #3
SeaSlugs
SeaSlugs's Avatar
Stuff I buy by the foot from the car parts stores I've had on mowers for 15+ years no probs...always been ran on E10...There is junk fuel hose out there as ive ran across it before and it gets hard as a rock...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-05-2017, 07:35 PM   #4
wmws
It is not all ethanols fault. I have had to replace all the low pressure fuel lines on a modern diesel tractor. They just get all soft and start oozing fuel.
wmws is offline   Reply With Quote
Old 06-05-2017, 08:11 PM   #5
Gunmetal blue2
Gunmetal blue2's Avatar
Sorry but when you guy or gals going to stop using rubber hose for gas lines. I saw a totally restored 69 corvette burn up because a guy used rubber hose for a gas line. why
Gunmetal blue2 is offline   Reply With Quote
Old 06-05-2017, 08:53 PM   #6
Brian in Wheeling
Brian in Wheeling's Avatar
Yeah, Gunmetal blue..I have to agree. Side of the road fix, O.K. Permanent...well?
Brian
Brian in Wheeling is offline   Reply With Quote
Old 06-05-2017, 09:27 PM   #7
Dick Steinkamp
Dick Steinkamp's Avatar
If this is truly fuel rated hose (either A1 or B1, NOT A2 or B2 fuel VENT hose) and it failed after 2 years, then all our fuel hoses on everything we drive would be failing every two years...and that isn't happening (at least to me).
There is info missing in this story.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 06-05-2017, 09:48 PM   #8
SeaSlugs
SeaSlugs's Avatar
same - if your heavy on additives like seafoam and it sits (ie all winter) it can eat into rubber if its too concentrated.
