Old 06-01-2017, 11:22 AM   #1
Fibber Mcgee
Fibber Mcgee's Avatar
Default Emergency Fender welt question
I'm in the middle installing the fender welt on my 41(thanks for all the previous advice) and can't remember if there was welting between the trunk and the fender and the chin piece and the fenders. It's been so long since I took it apart I forgot.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 06-01-2017, 08:06 PM   #2
Steves46
Steves46's Avatar
Default Re: Emergency Fender welt question
Maybe a long shot but try typing "1941 Ford Trunk" in Google, click on images and see what photos come up. Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 06-01-2017, 10:18 PM   #3
fordor41
fordor41's Avatar
Mine has welting that follows the rear fender all the way to the bottom of the fender, front and rear of the fender. welting in front goes from the top of the grill,actually the end of the latch plate down to the bottom of the chin panel and between the grill and the chill panel. is a bit of a fussy job. I installed welting to the front fender, then the chin panel. install the chin panel sort of loosely. slide the grill into place and tighten the bolts. I use nylok nuts so I can tightened as needed.
fordor41 is offline   Reply With Quote
