Old 05-18-2010, 10:45 PM   #1
Russ/40
Russ/40's Avatar
Default They said it would happen
Well, I've joined the club of those who break water outlet necks. I used a gasket on it and did not use the paper match trick. I figured the gasket was thin enough I would not have to worry. Well, it was fine on initial assembly, and appeared OK after the first retorque. I started it up today and ran it long enough to warm it up. All was OK when I shut it down. I went in the house and came out 30 minutes later to find the garage floor flooded, and the water neck broken. I thought if it wasent broken after torquing it would be OK. MISTAKE So to others who think it won't happen to them, it may not right away, but it will later. I destroyed a perfect original. Next one goes on with NO gasket and a touch of RTV.
Russ/40 is offline   Reply With Quote
Old 05-18-2010, 10:49 PM   #2
Model A Man
Model A Man's Avatar
Default Re: They said it would happen
I sand mine flat before installing
Model A Man is offline   Reply With Quote
Old 05-18-2010, 11:34 PM   #3
Preacher
T*** y** s*
If it ain't broke, fix it 'til it is ...
http://tcmafc.org/
Preacher is offline   Reply With Quote
Old 05-18-2010, 11:44 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I've seen the exact thing happen with the paper gasket. I heard a crack at a friends house and it seemed to come from his car. Checked it out and sure enough the water neck had just broken an ear off.
I've had good luck using the copper gasket. I think the paper gasket gets wet and soggy and thins out under the ear, then you have a snap.
Old 05-18-2010, 11:56 PM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
I file the surfaces flat if they need it and use Ultra Gray RTV without any gasket. Been doing that for 5 years now and have not broken one water neck, and no leaks either.
pat in Santa Cruz is offline   Reply With Quote
Old 05-19-2010, 12:04 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
How was it done back when? I cannot believe Ford would have gone through a bunch of water necks?
Old 05-19-2010, 05:49 AM   #7
Jim/GA
Jim/GA's Avatar
It was done with a thick gasket; two thin pieces of copper with some gasket material sandwiched between.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 05-19-2010, 05:50 AM   #8
peters180a/170b
peters180a/170b's Avatar
I have installed these time and time again with no problem. I use "ONLY" copper gasket ..BUT i keep some necks extra's on hand. :>)
peters180a/170b is offline   Reply With Quote
Old 05-19-2010, 06:26 AM   #9
2manycars
2manycars's Avatar
The original gasket was made just like a head gasket, with copper sandwiching a filler, probably asbestos. the paper gasket is junk, and should never be used, and the so called match trick is a lame attempt to overcome a bad gasket idea. If the correct original type gasket cannot be found, a thin layer of red high temp RTV on clean, flat head and outlet surfaces will never leak. Using RTV will also make the torque value more relevant on those two head studs, as there will only be one gasket to compress.
2manycars is offline   Reply With Quote
Old 05-19-2010, 07:14 AM   #10
SteveM
For the ignorant among us, what is the issue with the water neck that causes breakage and what is the "match trick"?
Steve
SteveM is offline   Reply With Quote
Old 05-20-2010, 10:47 PM   #11
Mike V. Florida
Steve
Place two paper matches on either side of the neck where the bolt holes are, as far out as possible.
The reasoning is that the nut pushs down on the edges of the neck more then the center, cracking the neck. Placing the matches under the edges make the edges higher then the center and prevents cracking.
Old 05-19-2010, 07:16 AM   #12
zzlegend
zzlegend's Avatar
I have used copper gaskets on 2 motors and not a problem.
zzlegend is offline   Reply With Quote
Old 05-19-2010, 07:43 AM   #13
Jerry Parr WI
Jerry Parr WI's Avatar
As you discovered the paper gasket is the culprit. Works fine when dry but becomes mushy when wet. The retorque then squeezes out the soft paper at the edge, breaking the water outlet. The match trick helps but the paper match will also become soft. The copper gasket works because the copper keeps the water away from the filler. I prefer the no gasket method.
Jerry Parr WI is offline   Reply With Quote
Old 05-19-2010, 08:08 AM   #14
kenparker
kenparker's Avatar
I file the two surfaces flat until I, using prussian blue as a mating surface check, have a 95% contack between two surfaces. Then using thin layer of RTV torque the neck down and havent broken one YET using this method.
kenparker is offline   Reply With Quote
Old 05-19-2010, 08:29 AM   #15
John LaVoy
John LaVoy's Avatar
I have used the RTV for years with out leaks or broken water neck.
John LaVoy is offline   Reply With Quote
Old 05-19-2010, 08:57 AM   #16
Marco Tahtaras
Marco Tahtaras's Avatar
I'll be the fourth person to emphasize both surfaces must be FLAT!
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 05-19-2010, 10:24 AM   #17
Russ/40
Russ/40's Avatar
The explanation given, that the paper gasket gets wet, and squishes out on the retorque sure sounds logical to me. Do I dare to use the copper gasket, or just go with no gasket? Anyone ever have one brake with the original type copper gasket?
Old 05-19-2010, 11:31 AM   #18
Special Coupe Frank
Special Coupe Frank's Avatar
Do the repro cast-iron necks also break ?
I just got a new one from Snyder's with the tapping for a temp sender; don't want to destroy it...
Special Coupe Frank is offline   Reply With Quote
Old 05-19-2010, 11:44 AM   #19
Mitch//pa
i was wondering about the repos also i cracked an original but the repo has been on and off many times and never cracked
Old 05-19-2010, 12:04 PM   #20
0rg0
0rg0's Avatar
Glad I read this. What about aluminum necks ? I have an offset generator mount, and needed to get a neck that shoots out at a different angle, and the one I found is aluminum.
0rg0 is offline   Reply With Quote
