Old 04-24-2017, 03:47 PM   #1
Sid
Sid's Avatar
Default Question about por-15 putty or filler
Has any one had any experience with the por-15 fillers? There is a patch and also a putty. As far as sanding,shaping,durability or top coating? I have a very very small spot on a roof next to the drip rail that needs attn. If I try to cut out and do a proper repair it will open up a big can of worms. Not to mention removing the headliner on a pretty much finished car. I would like to seal off the pin holes with the por-15 then use metal to metal to finish of any imperfection. This car will probably not see much rain in my lifetime. Will top with K-36 and base coat clear coat. Has any body worked with this product for this use? Which one works the best?
Sid is offline   Reply With Quote
