Old 04-21-2017, 01:44 PM   #1
32B
32B's Avatar
Default Model B 4 cyl water pump?
I see Mac's discontinued the water pump I was waiting to order. Anyone have one or a rebuild kit or a good used one? I really just need the impeller as the fins are rotted off mine, but would take about anything.
32B is offline   Reply With Quote
Old 04-21-2017, 01:48 PM   #2
fourfords
fourfords's Avatar
Default Re: Model B 4 cyl water pump?
Try posting in the "Swap Meet" section.
fourfords is offline   Reply With Quote
Old 04-21-2017, 03:41 PM   #3
Charlie Stephens
Try Renner's Corner. They are the "go to" guys for Model B parts. rennerscorner.com, (734) 428-8424
PS, I am glad you put this in the swap meet section as fourfords suggested
Charlie Stephens
Old 04-22-2017, 09:57 AM   #4
32B
32B's Avatar
Thanks Charlie, they have the rebuild kits but looks like they dont include an impeller. They also offer rebuilt units for $500. I'll keep looking or give them a call to see if they have any impellers they would sell.
Old 04-22-2017, 06:48 PM   #5
hardtimes
hardtimes's Avatar
Hey 32B,
Wow, $500 rebuilt ! There are two or three ways to go.
PM sent
hardtimes is offline   Reply With Quote
Old 04-22-2017, 08:45 PM   #6
koates
Macs have just discontinued their new reproduction model B water pumps. I bought one a few months ago and the front taper on the shaft was a little off on its angle and after an hour or so running the front pulley came loose and would not retighten. Contacted Macs and they eventually refunded my money. Had to send them photos of the pump shaft to prove their pump was poor quality. All a big waste of time especially the removal of the Headlight condutes, grille and radiator twice so as to unmount and remove the pump. Macs service and quality has slipped of recent times and I doubt that I will buy from them any more after having fairly good service from them over many years. I think Dave Renner is you best quality option but of course fairly pricey. He can supply all the pump parts you need even though they are not all listed, try him, great to deal with. Regards, Kevin.
koates is offline   Reply With Quote
Old 04-22-2017, 09:03 PM   #7
v8fordman
v8fordman's Avatar
I may have what you need. Will look tomorrow if you email me at [email protected]. Do you need a 1932 or '33-'34?
v8fordman is offline   Reply With Quote
Old 04-23-2017, 07:09 AM   #8
G.M.
There are adaptor castings to put a 36 V/8 water pump on the B
engine. Cools much better than the B pump. Google ford B pump
adaptor. G.M.
www.fordcollector.com
Old 04-23-2017, 08:06 AM   #9
Brendan
Brendan's Avatar
adaptor. G.M.
i had a 36 water pump on my A. the fan took out the pump
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 04-23-2017, 09:46 AM   #10
32B
32B's Avatar
I have heard about the fan issue. I am on my second fan and radiator due to failure. Im trying to stay original and avoid the adaptor option. At this point im either going to send mine to renners or see if anyone has one for me. Thanks everyone
Old 04-23-2017, 11:18 AM   #11
G.M.
I have had one on my B engine for close to 30 years. Went on a lot of long
tours. Cools real good and never had a problem. I'm not sure what fan I
am using, I think it's a 4 blade. G.M.
Old 04-23-2017, 11:38 AM   #12
DavidG
DavidG's Avatar
There's more to using the V8 pump than just buying the adapter. You may or may not have a better water pump, but you no longer have a fan unless you modify the V8 water pump pulley to attach a fan. That strikes me as something that would have to be done very carefully in order to avoid fan imbalance.
Old 04-23-2017, 12:42 PM   #13
hardtimes
hardtimes's Avatar
Hey G.M.,
Curious as to how you attached a cooling fan to the V8 pump on you B engine ? Currently , there are no such adaptors made to put a fan to an early V8 pump. Kling's used to make an adaptor for such fan use to early V8 pump. He told me this year, that he hasn't made such adaptors for years now...'not enough demand' to justify making them.
I have three different alum adaptors to mix/match various pumps to application, so am aware of those. Also , have good early V8 pumps that I'd like to use....but have to have that adaptor !
Old 04-23-2017, 01:21 PM   #14
Bob C
I don't have any information on these pictures.
Bob
File Type: jpg $T2eC16N,!)UE9s3wBePgBRNoEIrI7g~~60_57.jpg (33.1 KB, 232 views)
File Type: jpg $(KGrHqR,!iQFEz6nH0GPBRNoERbww!~~60_57.jpg (42.3 KB, 188 views)
Old 04-23-2017, 03:08 PM   #15
hardtimes
hardtimes's Avatar
Bob
Hey Bob,
Thank you for those pictures !
Wonder if that is Kling's 'invention/equipment' on the front of V8 shaft ?
Maybe someone has one or can identify this , over on the Model A side ?
I don't know how to get these pictures over there with questions.
I have the cyclone adaptor, one of three different adaptors on the shelf. Also have the other parts shown...except that fan holder ! Doesn't look complicated, eh ? Wish I knew machining, as I know that lots of inquiries for that adaptor in the past.
Old 04-23-2017, 03:42 PM   #16
hardtimes
hardtimes's Avatar
To help with 32B original question/search, I've got two (slightly) different rebuilt '3? pumps. Here are pictures. Can you tell which is which as to years ? How many versions were there between '32 and '34 years ??
Old 04-23-2017, 04:24 PM   #17
Charlie Stephens
Before I went to a V8 pump I think I would add some speed equipment most of which uses a Model A water pump.
Charlie Stephens
Old 04-23-2017, 04:29 PM   #18
Charlie Stephens
Unless you are getting into fine point judging there ae two pumps, '32 and '33-'34. The difference is the length of the shaft which allows for the radiator sloping back in '33-'34. You can usually spot the difference by looking at the spacing of the grease fittings on the left side. I can't tell for sure from your pictures.
Charlie Stephens
Old 04-23-2017, 04:45 PM   #19
DavidG
DavidG's Avatar
Those are both '32s with two of the many casting variations encountered. There are even a few with Ford script on the casting and some aftermarket ones as well.
The outer ends of the grease fittings on the '33-'34 version are only about an inch apart.
Old 04-23-2017, 06:43 PM   #20
hardtimes
hardtimes's Avatar
Charlie Stephens
Hey Charlie,
Now, that's just bragging ...geeze, nice engine bay !
But, I wouldn't do that ! Well, maybe just one pic of lonely B in waiting
BTW..thanks to David and you for you id help here !
