#1 |
New problem this year. Car doesn't start when hot. Good spark, amp meter jiggles when turning over. Never had a vapor Lock problem in the past.
Loosened carb filter bolt and had gas. Having gas at the filter bolt, does that mean carb has gas to start. Not even a putt , then all of a sudden it will start. Any suggestions? Bob Giles |
#2 |
Filter bolt? Is that the strainer fuel line in, or out? Or drain valve?
#3 |
It's the bolt that holds the filter screen by the inlet?
#4 |
When starting HOT, hold the throttle to the floor, until it goes RRRRRR!
Bill W.
#5 |
Do you have a good spark when hot? Are you opening the GAV to start?
#6 |
#7 |
This may not be your case, but we get in the habit of pulling the choke every time we start our A. Once the engine is warm there is no need to turn the GAV a full turn and pull the choke. With mine, when warm, a quarter turn on the GAV and no choke, she fired right up.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
#8 | |
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
#9 |
X3, if that is what is happening. I never use the choke or move the GAV once the engine is warm... starts right up.
#10 |
My car was hard to start when hot... sometimes, until I installed a phenolic spacer to isolate the carb from the hot manifold.
I don't have any starting problems now and seems to run better thru out the RPM range. |
#11 |
Hi Bob, if all else fails, I know I have a good running Carb. your more than welcome to borrow, it's not on my A right now so just let me know if you want to try it.
#12 |
To answer your question by loosening the filter bolt it means you have fuel getting to the carb. It does not mean you have fuel going thru the screen or past the float valve to fill the bowl. If you remove the 1/2 wrench size bolt under the carb that will tell you if your bowl has fuel in it..
#13 |
Thanks Joe.
Mitch, that's the answer I was looking for. |
