Old 04-03-2017, 09:10 AM   #1
cordbob
Default 48 Mercury convertible
still having problems we replaced hydraulic ram cylinders That were leaking driver's side Works faster than passenger side Believe air is in system anyone have any idea how to bleed it out have tried running the pump up and down with the top disconnected from Rams one book I have says to hold the system in the down position after the Rams have stopped moving that does not seem to work to bleed out the air after the drivers Ram extends up or down completely the passenger Ram will pick up speed
cordbob is offline   Reply With Quote
Old 04-03-2017, 10:30 AM   #2
cordbob
Default Re: 48 Mercury convertible
finally got it figured out have to have the top hooked up to the Rams one will always move faster than the other is it self bleeding system if anybody needs any information or parts for a convertible top call these guys:
Hydro Electric 800-343-4261
