Old 04-02-2017, 02:34 PM   #1
corvette8n
corvette8n's Avatar
Default Dwell meter question
Found a dwell meter from early '70's on my garage wall, it has only two connections on it red & black(I assume + and - ). My question is where do I hook this up to test with? My car is a '41 v8 with a remote coil kit, can style coil is mounted on fender. Only instruction on meter is to double the reading when testing a four cylinder. What kind of reading should I get on the dial?
Old 04-02-2017, 02:37 PM   #2
40cpe
40cpe's Avatar
Default Re: Dwell meter question
On a negative ground system the red goes to the distributor terminal ( - ) on the coil, black to ground. I'm not sure how positive ground would affect it. If it doesn't work, reverse the leads.
40cpe is offline   Reply With Quote
Old 04-02-2017, 03:08 PM   #3
tubman
tubman's Avatar
I bought an old cheapo unit at a garage sale. On mine, if you hook up power to the unit and ground the right way, it works just fine. Seems to read correctly, too. I like it so well, I permanently mounted it on my engine test stand.
