Old 04-01-2017, 12:52 PM   #1
V8Germany
V8Germany's Avatar
Default How do I install a windshield regulator ?
Dear All,
My 1936 Fordor has no windshield regulator,
the previous owner just installed a threaded rod with a handle.
Now I got a regulator from MAC to bring the car back "original "
and thought it is easy to install 😌
4 screws and done....
Well... the MAC assembly is to large/ wide for the gap between dashboard
and window frame....
Do I have to do something with the dashboard or can I sneak the
assembly in from below ?
Thank you for your help :-)
BB
V8Germany is offline   Reply With Quote
Old 04-01-2017, 01:14 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: How do I install a windshield regulator ?
I installed one of Bob Drakes repro windshield regulators in my '35 fordor sedan. The one you got from MAC's probably came from the same original source. I had to remove some of the slotted oval head screws, that are normally hidden behind the ws frame, that fasten the top of the dash to the windshied openning of the body. I'm thinking it was several of the ones near the opening that the regulator arms come through on both sides. This allowed that opening to be expanded enough to get the winder mechanism or arms through. After that, everything bolted in place and worked well.
John
Old 04-01-2017, 01:15 PM   #3
JSeery
JSeery's Avatar
There is an installation sheet on Drakes site (I think it's Drake).
Old 04-01-2017, 01:21 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by V8Germany View Post
Dear All,
and thought it is easy to install ��
Thank you for you help :-)
BB
Does your new regulator look like this? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-01-2017, 01:37 PM   #5
V8Germany
V8Germany's Avatar
V8COOPMAN
Yes that's the one I purchased.
BB
BTW: ordered from MAC but part was in Drake box.
Old 04-01-2017, 02:12 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
BB........Read CAREFULLY just above from JM 35 Sedan. He explains how he installed the same (DRAKE) regulator in his '35 Ford. You will need to remove the INSIDE windshield trim pieces. This will allow you to see the fasteners that secure the TOP edge of your dashboard. You will need to remove several fasteners at the TOP of dash so that you can flex the top edge of dash to make enough room to slide the new mechanism in. Make sure you lubricate the TEETH and winding mechanism on the new assembly with white lithium grease, or equivalent. Hope this helps. I'm sure that if you have questions, you can PM JM 35 Sedan and he will give you GOOD advice. DD
T5 W/TORQUE TUBE
Old 04-01-2017, 02:17 PM   #7
V8Germany
V8Germany's Avatar
Wonderful guys, thank you very much. Amazing how much know how
and helpfulness you offer.
BB
Old 04-01-2017, 02:31 PM   #8
rich b
rich b's Avatar
You may also have to loosen or remove the the two fasteners in the lower corners in the dash to get the dasp to move far enough to get the regulator in place.
rich b is offline   Reply With Quote
Old 04-01-2017, 03:45 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
BB..........Here's a picture showing the REAR side of a dash, the clear slot in the upper middle, and the area where the regulator fits. Thought this MIGHT help you see what you have to work with. Someone has cut the arms on this one. DD
T5 W/TORQUE TUBE
Old 04-01-2017, 04:39 PM   #10
V8Germany
V8Germany's Avatar
Great, that definitely helps a lot.
Thank you for all your efforts!
Old 04-01-2017, 09:11 PM   #11
jake197000
i have to pull the one in my 39 coupe to fix it.is it the same procedure ?
jake197000 is offline   Reply With Quote
Old 04-02-2017, 10:44 AM   #12
JM 35 Sedan
I dug up some pictures I had taken when replacing the windshield regulator in my 35 fordor, but unfortunately I can't post them here now because of some type of problem on this website. If/when this changes, I'll come back and post them.
John
Old 04-02-2017, 11:25 AM   #13
4dFord/SC
4dFord/SC's Avatar
Maybe you can exchange email addresses via PM and send them to him that way. Just a thought.
4dFord/SC is offline   Reply With Quote
