Old 04-01-2017, 11:26 AM   #1
OLD AS I
OLD AS I's Avatar
Default Muffler inlet-outlet
Took my dual exhaust system off, took pictures prior to removal and had them loaded on my computer with all my other pictures and lost everything, YES, now learned the hard way to back up.
Don't know which end is which, if infact is there a difference ?, think I've seen mufflers marked inlet/outlet . Only markings is model #HOF7055 but Google brings up nothing. Anyone have any idea if it makes a difference, see picture here, both are 2" ID / 2 1/8"OD, connection points are off set to one another.
Picture wont attach
OLD AS I is offline   Reply With Quote
Old 04-01-2017, 11:39 AM   #2
WestCoast
Default Re: Muffler inlet-outlet
usually on the inlet side of the muffler you will see a bunch of serrations that look like small louvers, the rounded part of the serrations point to the inlet side of the exhaust gases. I have run the mufflers both ways, all it does id create a little more back pressure and changes the sound of the muffler, usually louder, if the mufflers are oval or flat make sure the seam id down, in case of a blown muffler the hot gasses will not hit the floor boards of the body, if you have a glass pack muffler to look at tou will see the louvers im talking about
WestCoast is offline   Reply With Quote
Old 04-02-2017, 06:59 AM   #3
OLD AS I
OLD AS I's Avatar
trying to post picture again, get the following message
The website cannot display the page
HTTP 500
Most likely causes:
  • The website is under maintenance.
  • The website has a programming error.
What you can try:
[IMG]res://ieframe.dll/bullet.png[/IMG] Refresh the page.
[IMG]res://ieframe.dll/bullet.png[/IMG] Go back to the previous page.
[IMG]res://ieframe.dll/down.png[/IMG] More information
Old 04-02-2017, 08:05 AM   #4
JSeery
JSeery's Avatar
Yep, join the club! This has been going on for about three days.
Old 04-03-2017, 07:12 AM   #5
OLD AS I
OLD AS I's Avatar
Trying to check that pictures can be posted now, been told its corrected, YEP, works now
