Old 03-31-2017, 04:21 PM   #1
jimTN
Default pulling stock 32 engine
I have never pulled a 32 engine and ran into fun right away with the radiator mount sticking under the fenders on both sides, is that correct, there were also pads under there also. A hard shift to one side and picking up the other side got it out. I am pulling the engine and trans. as one unit, trans has some bad gears to be replaced. What is the easiest way to line the rear mt in the frame going back in?
jimTN is offline   Reply With Quote
